05-27-2019, 12:31 PM
Levelers Down ?
I was wondering when your RV is not in use do you put the levelers down to take pressure off tires and keep roof level ?
Jeff
05-27-2019, 12:33 PM
We usually do, but we we don't keep it level, we angle it a little to keep water running off of the roof.
05-27-2019, 12:59 PM
I don't leave the levelers down, don't want the shafts exposed to the weather. Periodically I will extend them and exercise the slides, generator, awning and also do a few mile drive to help preserve the tires and mechanical components.
2018 DX3 37RB - 2017 Jeep GC Summit towed
05-27-2019, 01:02 PM
DW's 401(k) Plan
Hmmm... never gave it much thought. Usually I have the front tires on ramps to kind of level it out - I back into my driveway and it's an incline up my driveway. However, if the driveway were level, I probably would.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
05-27-2019, 07:02 PM
We leave the jacks retracted when parked in storage. Same idea with leaving the shafts exposed too long, and I dont see a need. I figure the suspension and the tires are made to leave sitting, not the jacks.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
05-28-2019, 08:33 AM
I believe either the dynamax manual or the leveler manual states the jacks should be either retracted sprayed with silicon weekly during long stays to prevent corrosion on the shafts.
I do not store with the jacks down. Tires are a consumable part, jacks are not.
2016 Dynamax DX3 - Big Blue
05-28-2019, 08:53 AM
Depends where you're parking, but if you're thinking that taking the weight off the tires is going to have some major benefit, think again! Mine's on blacktop and yes the stabilizers are down because we may put the slides out, but, off season... nope! If you want to do something for the tires (and your driveway), put it up on a set of 2 x 12s. Get some tire covers. Shouldn't matter whether tt or mh
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
05-28-2019, 09:12 AM
Commercial Member
I think even the leveling guys say not to leave them extended. (at least HWH used to). Especially near salt water. The shafts themselves are exposed, can start to rust and get pitted which then works away at the seals.
08-25-2019, 08:59 AM
Seņor Miembro
So if we are storing the RV at our home for he winter but want to have the slides out, we should level the unit on jacks, put out the slides and then retract the jacks?
We'll just need to remember to re-level before we retract the slides in for the next trip? Or will that throw something out of kilter? Will the slides settle or anything if left out for 6 months?
08-25-2019, 09:41 AM
Commercial Member
Are you storing it on a cliff? If it is pretty level, I'm not sure you would need to level.
If it is un-level, I would not suggest what you are proposing, but to leave it with the slides in.
08-27-2019, 02:54 PM
Seņor Miembro
I haven't seen documentation prohibiting perching on a cliff. I did see a label about not using the toaster while taking a bath
No, we have a few fairly level spots. Our industrial asphalt driveway apron is sloped just enough for water run-off, about 3/8" per foot long ways and fairly flat side to side.
I just want to make sure we aren't going to make another problem by not using the jacks and leaving the slides out for 6-8 months like that. Are you saying we only need to use the jacks for unlevel spots before using the slides ?
Also, is it OK to leave it plugged in the whole time for minimal heat or cooling? I'll still winterize the water systems JIC.
Do you foresee any problems with how proposed storage plan?
08-27-2019, 03:06 PM
Commercial Member
If you are mostly level, you shouldn't have any issues. No reason you can't leave the slides out and lots of people leave them plugged in year round. I think HALLA has mentioned that a few times and I know several others as well.
And yes, I am saying if you are pretty level, you can operate the slides without jacks. Jacks are mainly to "get" level when you are unlevel. And they do offer up some stability.
