Ok, sorry for the long post (cross-posted on Facebook forum as well)...
This is regarding the particular combination of Isata 5 (ours is 2017 35DB, but others may have same situation), Dynamax-installed Equalizer hydraulic levelling system, and Kelderman front/rear air suspension with their mechanical self-levelling controls. Comments about other combinations such as electronic controlled Kelderman, front only, manual fill, etc, will only add to our confusion, so please refrain. Don't respond with "you need to reset your null", as that's not my issue.
1) According to Equalizer, their system is for LEVELLING, not just stabilizing, and is capable of supporting the full weight of the vehicle. (We try to avoid this, just what they state).
2) According to bclemens and other Dynamax reps, one should NOT have any of the wheels in the air unsupported in the final levelled configuration. This could result in stress on the cab-to-box/overcab bunk joints/seals, and possible stress to suspension components.
3) Some have recommended blocking under any wheels that get airborne. This seems to go against the purpose of #1, but with the warnings of #2, I get it.
4) On the Kelderman suspension (at least with the mechanical self-levelling control system), as soon as you unweight a corner, the associated valve will drop air from that corner (trying to bring it back to level), thus leaving that suspension corner essentially hanging. Even IF not unweighted, any air leak (which we have a small one), will deflate the bag and transfer weight to the Equalizer jacks.
Our dilema; therefore, is that we appear to be screwed regardless of levelling method chosen: If we just let the Equalizer do its thing, we often will have wheels up in the air (regardless of resetting the null, so don't go there). Even if wheels don't go off the ground, they will still be unweighted, emptying the associated corner's airbag, so fully supported by Equalizer jack only. If we go to the trouble of blocking each tire up so it's level to start with, then the Equalizer becomes a (very heavy) stabilizing jack setup, so what's the poing?
Looking from advice from those in (hopefully exactly) the same situation, or bclemens, as to what the solution should be.
TLDR: How do you guys use your Equalizer with 4-corner Kelderman suspension?
-Ken
