Originally Posted by hines5000
I have a 2015 DX3BH. Will the 2021 couch and dinette fit in my slide length wise? My service person just told me that the part number given to me by Dynamax parts are longer available from Lippert.
OK, Mark is correct, we no longer do those comfort lounge setups. (LCI just doesn't make them any more). He was just in here and I was going to have him explain, but its best if I give some direction.
I forgot that we had some 15's still with the curved walls (that was the year we switched) so it gets a little complicated.
I am guessing you have the comfort lounge & barrel chair pictured below.
In theory, the slide lengths are the same. So today's Sofa/Dinette combo should fit (it can't be just the sofa as your dinette is completely different). The dinette we use today is about 70 3/4" (42" deep) and the sofa is roughly 64".
If you measure the slide, side to side, we can confirm it will fit. BUT you also need to measure the depth. I can't remember if we made the slide floor deeper to accommodate a bigger dinette or if the we made the dinette bigger to take full advantage of the slide floor.
The 2nd picture is what we run today.
They are also not doing barrel chairs. I would recommend finding a "Euro recliner". It will be more cost effective as they come in stock colors, black, beige, gray. (keeps costs down).
As for driver/passenger seats. They also don't make those seat frames anymore as we stopped using them and changed to stock seats. You could get a stock seat from Freightliner, but you would need a stock pedestal as well.
PS. In the end, it might be better to try and source stuff from Rec Pro. "in stock" stuff with stock colors will be way more cost effective than custom stuff (IE our colors) and our costs have doubled on furniture in the last 6 months. Most of our suppliers will not even sell us retail furniture as they can't keep up with OEM demand.
A ladder supplier just canceled 100% of all backorders and service orders as they had no hope of filling them. They then allocated quantities to each plant based on historical numbers. So if you had 300 on order, they canceled them and told you that you can now have 40 per week...that's it. I would venture to say a lot of OEM's will start deleting ladders. (we were ahead of the curve)
