Old 02-23-2024, 12:51 PM   #1
LP tank gauge & filling on a Isata 5 28SS ?
We have a 2023 Isata5 28SS and the LP gas gauge has not worked correctly since the day we drove off the dealers lot. We have used some LP in the last two months and the gauge dropped from full to 40% overnight so we had it filled, but they couldn't get any into the tank, they said it was full. After they attempted to fill it the gauge went to 30% and one day later it reads low.
My immediate concern is why it wouldn't take any gas because we definitely have used some. Has anyone had this issue? Can anyone tell me if there is a gauge directly on the tank, and if it is easily accessible in the truck frame?
2023 Dynamax Isata5 28SS
2023 Ford Bronco
2023 Ford F150 Tremor
Iowa Hawkeye is offline   Reply With Quote
Old 02-23-2024, 02:30 PM   #2
firedude2's Avatar
Not sure where your tank is located but I think it is the same size as mine and there is a gauge on the tank. If you were full and have only used it a few times (unless high furnace use)you probably did not use much. Check that tank gauge.
2023 Dynamax Europa
firedude2 is offline   Reply With Quote
Old 02-23-2024, 05:59 PM   #3
Isata 5 propane
Lots of threads with this topic . . .
Use the search box above (upper right corner of web page) and enter 'Isata 5 propane'
https://www.forestriverforums.com/fo...-227099-2.html is one of the threads found with the search.
Good luck with getting your propane flowing and usable again.
2012 Rockwood A122, 2017 2018 Kia Sorento 3.3 V6 AWD,
(2012 Subaru Forester with MT & the 2017 Sorento have gone to TV heaven))
Cheers and greetings from a Toronto Canuck
Brandoni is offline   Reply With Quote
Old 02-24-2024, 12:23 PM   #4
Lvnthedream's Avatar
My valve had to be replaced. https://www.forestriverforums.com/fo...ds-227099.html
2021 Isata 5, 34DS
Colorado
Lvnthedream is offline   Reply With Quote
tank
