Old 06-09-2021, 06:23 PM   #1
M2/DX3 Sanicon replacement
Sorry to start a new thread, but, after a couple days of troubleshooting, I've eliminated the possibility of an electrical issue and have concluded that the pump is shot. I'm assuming there's no 'good' way to break the inlet and outlet glued fittings off the sanicon box, but if there is I'm all ears.
If you unbolt the waste valves, can the inlet assembly circled in red on the right be removed with the sanicon box? If so, is there any chance that this entire PVC assembly and the outlet elbow on the left be purchased from Dynamax parts?
Thanks!
JT
2018 DX3 37BH
mookieblaylock is offline   Reply With Quote
Old 06-09-2021, 06:43 PM   #2
I guess I should have looked around online first. Anyone know if these would work to replace the inlet assembly from the waste valves to the sanicon box?
https://www.amazon.com/Valterra-T103.../dp/B002N5POME
https://www.amazon.com/Valterra-LLC-.../dp/B00TPWI0PQ
Might as well go ahead and replace the valves while I'm in there I suppose...I've suspected that the grey tank valve has been leaking for a while.
2018 DX3 37BH
Old 06-10-2021, 06:00 AM   #3
FOURWHL's Avatar
Dynamax gets that whole pipe assembly fabbed already. May just want to see if they will send you one and then you can just swap it all out at the rubber boot at the tanks.
2016 Dynamax DX3 - Big Blue
Full-time Dynamax Resident
FOURWHL is offline   Reply With Quote
Old 06-10-2021, 08:25 AM   #4
Roger that...I'll contact the parts department.
Thanks for the info!
2018 DX3 37BH
Old 06-10-2021, 10:32 AM   #5
KRedburn's Avatar
I believe that the motor is replaceable in that unit. It is removed from the bottom.
Thetford Sani-con parts.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 06-10-2021, 12:10 PM   #6
I thought so as well, but if you look at the parts page it only shows the pump replacement with the tank or the tank alone:
https://www.thetford.com/part/sani-con-turbo-700/
I found a pump that 'might' work, but I couldn't find any definitive info that said it was the same one. So I just bought part number 97518.
2018 DX3 37BH
Old 06-10-2021, 09:55 PM   #7
Lonestarcj7's Avatar
They won't sell just the motor, I tried that last year. Took mine all apart, contacted Thetford and they said I had to purchase the whole unit.
Availability of the unit was also a problem, had to go through an "authorized dealer".
2018 Dynamax DX3 37BH #JHJJ6635
Shepherd, TX
Lonestarcj7 is offline   Reply With Quote
Old 06-23-2021, 02:02 PM   #8
Just to close the loop on this one, I ended up replacing the entire pump/housing assembly. In order to do so, most all of the ABS components also needed to be replaced.
While I in there I ended up adding a second elbow to the outlet port of the Sanicon and directing this pipe (and the ultimately the flex hose) below the housing towards the large center hole in the bin. This keeps the hose from kinking so much when routed out this port in the bin and also keeps the hose away from strut on the bin door (which always seemed to rub).
Also, while the traditional slinky connection worked fine to dump the tanks after the pump gave up the ghost, opening that cap and then disconnecting the slinky after dumping was not pleasant. Due to the design of the pump housing, about 1" - 1.5" of waste water is retained in the bottom. This likes to run out when the cap is removed. So, rather than replacing this with the original hub-to-lug style fitting, I added another 3" waste valve here in case I have to use it again in the future (hard to see in the pic, but the black handle pulls horizontally towards the hose reel).
After getting the old assembly out, I tried to take it apart just to see if I could figure out what got lodged inside and likely caused the failure. Two comments/notes from that:
1) As mentioned, it does appear that the pump itself could be replaced. It's Thetford part number 97508, although I never came across any for sale online. Assuming you could find one, it's removable via the top, but the 4 screws that mount it inside the housing were incredibly corroded. I tried to get a couple of them to loosen up, but, as you could imagine, it was messy.
2) The manual illustrates a clear access panel on the bottom of the housing (I didn't even know this was here). According to the manual, this serves two purposes - a) to view the impeller to see if there are any obvious obstructions and b) to remove the impeller cover to remove any obstructions if found. While you can see this clear access panel from below the storage bin with the center cap removed, the consistency of the water remaining in the bottom of the housing does not allow you to view the impeller even after flushing the tanks for a while (your results may vary). Before taking it all apart, I removed this very carefully and let everything drain out into a bucket. I could see the impeller at that point and could actually spin it with little effort. I could also see the screws that mounted the impeller to the bottom of the pump. Although the manual specifically says to remove the impeller via this access panel, I could see any way that would be possible.
tl;dr - if this happens in the future, I'll just replace the entire pump/housing assembly again.
I'm adding the parts below just in case it helps someone else (and so I can find it when I have to do it again):
97518 - Qty 1 - Thetford SANI-CON Macerator Pump TOILET COMPONENTS RV
344632451 - Qty 2 - LaSalle Bristol Street Elbow Fitting for RV Sewer System - ABS Plastic - 90 Degree - 1-1/2"
344632891 - Qty 1 - LaSalle Bristol Adapter for RV Sewer System - ABS Plastic - 1-1/2" FPT
34466ND14AAR - Qty 1 - Bristol Double RV Waste Valves - Elbow - Rotating - 3" and 1.5" Hubs to 3" Spigot
34466N5A - Qty 1 - Bristol Waste Valve for RV Black Water Tank - 3" Hub to 3" Lug
632278 - Qty 1 - LaSalle Bristol 3X90 ABS 90 Degree Elbow
5817 - Qty 2 - NIBCO Cap Hub - ABS DWV, 3"
JT
2018 DX3 37BH
Old 06-23-2021, 02:12 PM   #9
FOURWHL's Avatar
Nice work and write up! I'm sure I'll be digging this back up at some point.
Definitely agree on the gate valve on the 3" port. I may do that preemptively to save myself some mess.
Old 06-23-2021, 02:23 PM   #10
Travler's Avatar
After reading this I was thinking the same thing about adding the valve before trouble hits.
2017 Dynaquest 37RB
Travler is offline   Reply With Quote
Old 06-23-2021, 02:31 PM   #11
Bill Davis's Avatar
X2
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
Bill Davis is offline   Reply With Quote
Old 06-23-2021, 03:50 PM   #12
CyberShanks's Avatar
Location: Top of a hill (in Iowa) surrounded by corn. Dynaquest XL 3400KD ON ORDER!
Did very same thing already on our Imagine trailer. Will likely be doing it to the XL as well. FWIW, I just cut the 4 pins off of the outlet and PVC glued the gate right to it. Never will fall off
Jim
CyberShanks is offline   Reply With Quote
Old 06-25-2021, 09:22 PM   #13
Ender's Avatar
Wow, all the people on this forum never cease to amaze me!! My macerator quit working so I jumped on to do a search and bingo....first page....exactly what I needed. Thanks so much for posting this!!
I need to tackle this same job....where did you end up getting your parts?
2018 Dynamax Force HD 37BH
AKA "Thunderwagon"
Ender is offline   Reply With Quote
Old 06-26-2021, 08:02 AM   #14
I found the macerator on ebay. All of the ABS pieces came from e-trailer except for the 2 caps and the long sweep 3" elbow. Those came from Amazon. Let me know if you need any links; I can probably dig them back up.
JT
2018 DX3 37BH
dx3, replacement
