07-23-2022, 10:05 AM
#21
Yes I don't like the play in the receiver. It's all the adapters. I looked into alternatives. One is a new 2 inch that would eliminate the adapter from 3" TO 2" https://www.etrailer.com/Heavy-Duty-.../41990-16.html.
07-23-2022, 04:05 PM
#22
Originally Posted by cashman240
Ok if not pulling heavy loads, that would reduce the towing capacity of my DX3 by 4,000 lbs as well as 1,400 less tongue weight.
2015 DX3 37TRS - Brutus
B'ham - or at a racetrack
07-25-2022, 11:36 AM
#23
The Europa is on a M2 106, and has a 2" receiver hitch. I wonder if that hitch will bolt onto a DX3.
07-25-2022, 11:44 AM
#24
One sure would think so, I'd assume that the tow rating would need lowered to 12k with 1200lb max tongue weight too.
Jim
2021 Dynamax Dynaquest XL 3400KD
2022 Aluma 8220H Tilt flatbed to carry:
2012 Jeep JKU Rubicon or slightly modded 2001 Jeep TJ
07-26-2022, 02:02 AM
#25
Why not just use the 3” weigh safe? I have them in stock and give all forum members a discount. PM me.
—John
07-26-2022, 11:30 AM
#26
I'm using a tow bar
07-26-2022, 08:07 PM
#27
We use a Trimax anti rattle clamp. Bought from Canadian Tire in Canada. They have them for 2 and 2.5 hitches. Can say there is no movement or rattling. I didn't like the side to side play in the tow bar when towing the Jeep.
2021 Isata 5 28SS Explorer
2017 Jeep Wrangler Unlimited Rubicon Recon
2017 Ram 3500 DRW
07-30-2022, 09:58 PM
#28
Finally found a design that fit over our M2 112 receiver lip and eliminate the movement. Made by Bulletproof.
07-30-2022, 10:57 PM
#29
Attachment 277216
Nice! Thank you!
2022 DynaQuest XL 3400KD CabOver, WD, Lithium Batteries, 4 190Watt Rigid Panels, extra inverter for AC operation w/o Genset.
07-31-2022, 10:10 AM
#30
Attachment 277216
Stupid question, but I assume you ordered the 3” one, correct?
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
08-01-2022, 09:21 AM
#31
I just picked this up. While not helpful in the "rattles" category, I definitely am so very happy not to be dealing with 2 independent step downs (3 to 2.5) and (2.5 to 2). One massive beefy step down is much better from 3" to 2"
https://www.amazon.com/Towing-Traile.../dp/B07QX7VY9C
2022 Force HD 37TS
---- FORCE of Nature ----
22FT Full Tilt PJ Trailer for the Toad and Toys
11FT Triton ATV Trailer / Artic Cat SXS
Retired: 2011 Dutchman Aerolite/2015 FR Heritage Glen
08-02-2022, 04:32 PM
#32
[QUOTE=FORCE of Nature;2767993]I just picked this up. While not helpful in the "rattles" category, I definitely am so very happy not to be dealing with 2 independent step downs (3 to 2.5) and (2.5 to 2). One massive beefy step down is much better from 3" to 2"
Does this have a 3/4" hitch pin hole or a 5/8"?
2021 Dynaquest 3801TS
2023 Rubicon JLU Xtreme Recon
2020 Jeep Wrangler Limited Willys
08-02-2022, 04:39 PM
#33
[QUOTE=MAC D;2768583]
5/8", just confirmed in the garage.
2022 Force HD 37TS
08-02-2022, 05:12 PM
#34
I was just looking at that but I wasn't sure how the different hitch pin sizes was going to work. Any thoughts? Sleeve a 5/8" somehow?
Something like a Draw Tite 38735 will allow for a 3/4" hitch pin on the 3" side and a 5/8" pin on the 2" side. And the 38735 has the additional hole for a J-Pin.
08-02-2022, 07:30 PM
#35
Good foresight! That Draw Tite is very nice. I may just have to add that one to my arsenals as well. I have never held back from buying an adaptor that proves useful, especially when they are of the "giant hunk of metal" variety that I know will be around for a lifetime.
That said, I do own a Pin that indeed came with a 3/4" sleeve to slide over the 5/8" and increase its OD.
2022 Force HD 37TS
