Old 10-23-2021, 12:48 PM   #1
Trialrun85's Avatar
M2 Installing New 12v circuit. How/Where to tap
All,
I am sure this has been covered but cant seem to find it. The great folks at Dynamax Parts sold me new seat skins as mine had turned to dust. I already installed the drivers side and then it dawned on me that now would be the ideal time to make the seats heated.
From wherever I tap for the heater ( most likely has to be the fuse block upfront) I only want 12V when the engine is running.
But in general, has anyone installed a sub fuse block somewhere in the cab or coach that makes it easier to add things down the road?
I am thinking 1 small fuse panel that is always on for certain things and 1 small fuse panel that is only hot with the ignition on.
Thanks in Advance,
John
2016 Dynamax Force 35DS
2014 Chrysler T&C or 2015 Ford Fusion Toads
On a Master Tow Dolly
Trialrun85 is offline   Reply With Quote
Old 10-24-2021, 02:06 PM   #2
halla's Avatar
I have a sub fuse panel up under the left side of the steering column. I run the subwoofer, amp, seat heaters etc.
I put in a 100amp fuse in the electric bay, ran a new ground and power from that fuse to up under the dash to the new panel.
I also put the new power line on a shut off switch in the electric bay in case it ever needs shut off.
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 10-24-2021, 11:07 PM   #3
Trialrun85's Avatar
Halla, Thanks for the info on your setup. I was also trying to figure how many amps to run. Did not think of amplifier and subwoofer. My radio could use those for sure someday, so I will do similar. Maybe make a couple circuits ignition on only for drain protection. Did u run #4? Recall Feet?
Old 10-25-2021, 06:52 AM   #4
halla's Avatar
8awg wire from Amazon, bought 50' of each (Red/Black). I used probably 25-30' of it total. I ran out the back of the cabinet, up along the frame rail. Under the plastic scuff plate on the drivers door is a wire loom that enters there. I came up through that and then up to the firewall. My panel is not keyed, it is powered on all the time, but the amp and the sub have a power on/off wire that controls those. The seats we have to remember to shut off, which hasnt been an issue so far.
Old 10-25-2021, 08:51 AM   #5
Trialrun85's Avatar
Halla, Thanks again. Do people seal up the grommet hole in the firewall when they pass a cable through with some type of waterproof pass through connector?
Old 10-25-2021, 08:59 AM   #6
halla's Avatar
The firewall hole I have sealed up, I just used some butyl around the wires, keeps everything out and never really dries and falls apart.
12v, subpanel, tap
