Old 09-30-2020, 07:40 PM   #1
EdandShelley's Avatar
Macerator Pump not working
Hello everyone
Have a new challenge this evening.
Our Mecerator was working just fine on the last trip and when we put the RV in storage.
Tried using it today but itís not powering at all.
Checked fuses inside and all look good.
Any ideas?
EdandShelley is offline   Reply With Quote
Old 09-30-2020, 08:11 PM   #2
Originally Posted by EdandShelley View Post
Hello everyone
Any ideas?
Here's thread from earlier this year that might help:
https://www.forestriverforums.com/fo...or-200420.html
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-30-2020, 08:45 PM   #3
Could use a little more guidance.
I read in that thread there is a fuse in the electric bay. I just looked in the bay and canít identify a fuse that is blown...am use to circuit breakers like what is under the bed or blade fuses. Is this another type of fuse and can I simply reset it?
Old 09-30-2020, 09:05 PM   #4
Checked all the fuses I could find in the electric bay. All ok.
Old 09-30-2020, 09:41 PM   #5
Worm43's Avatar
The fuse is one of the 30amp fuses to the right of the panel. My macerator went out and had to be replaced by the manufacturer.
2017 Dynaquest 37XL RB "Thor"
2016 Jeep Wrangler JKU
Worm43 is offline   Reply With Quote
Old 09-30-2020, 10:42 PM   #6
I see a few 100s but thatís it. I must be overlooking it or have been staring at the mass of wires too long.
Does anyone have a picture of what I need to be looking for? Thanks so much in advance.
Old 10-01-2020, 11:20 AM   #7
Did some voltage testing.
14.2V at the switch
14.2V at the Sanicon when the switch is on
Looks like the mercerator pump may have died. Just very strange since it worked going into storage and doesnít now.
Anyone know if these have any form or a reset or anything else to check?
Also, what are the two smaller gauge wires going into the pump?Click image for larger version
Old 10-01-2020, 11:50 AM   #8
I'm hesitant to post this because I don't know the details, but I'm pretty sure there's a 'thermal' fuse within the unit as well. I've had to pump mine through a 3/4" garden hose about 75' before, and, after running for a good while, it shut off. After checking power and and all the fuses just like you've done, it started working again (presumably after it had time to cool off).
I realize yours has been in storage and wouldn't be 'hot' at this point...just noting something else that could have failed. I'll try to find it in the manual.
EDIT - scratch all that...looking at the diagram, the thermal fuse provides a path to ground through the switch for the relay to trigger. If you're seeing 14V at the pump with the switch 'on', then the thermal fuse is intact. Sorry for the confusion.
2018 DX3 37BH
mookieblaylock is online now   Reply With Quote
Old 10-01-2020, 11:54 AM   #9
Worm43's Avatar
Sanicon fuse is the 30am with the two red wires. Same thing happened to me. Power all around and pump would not turn on. No garbage restricting propellers. Just died.
Old 10-01-2020, 12:34 PM   #10
Thank you. That was exactly what I needed to see.
Checked the fuse... all good.
Called Thetford customer service and thought we were looking at a burned out pump. Jumped the pump directly to the battery and it still wouldnít run.
Then, as I began to remove the mounting bolts to check for a jammed impeller...it came on... cool. Fortunately my hand wasnít in there.
Began tracing wires and found a connection that had vibrated loose. It was one of the smaller blue wires coming out of the pump. Re stripped all wires and reconnected to fast connectors.
Thanks for the help everyone.
Old 10-01-2020, 03:03 PM   #11
Odd. According to the diagram, the two 18g blue wires coming from the pump assembly connect to either side of the thermal fuse (switch) - one from the main switch to the thermal fuse, and the other from the thermal fuse to ground. I'm not sure how you were getting 14V at the pump if either of these blue wires were disconnected.
A win's a win, though...glad you found the issue and got it back going.
2018 DX3 37BH
Old 10-01-2020, 04:18 PM   #12
Not sure myself but I will take the gift of an operating Shi!!@£ any way I can get it.
pump
