Originally Posted by bclemens
Likely availability. We don't typically mix and match unless it serves a purpose.
Are you original owner? We avoided the Xantrex for a while because people kept pushing the red power button thinking it would disable the inverter, but it really put it in "Standby Mode" which did not even allow pass-through power. They they thought something was broke.
I am not the original owner. I am the second owner. I run working K9's and when I'm boondocking I want to run the generator at a certain temp or voltage. With the little wheels on the standalone, it's hard to get the right temp but I think I finally got it. So now that it's working I probably don't have to mess with it anymore.
My only other issue is that now and then, when I'm leaving my thermostats on for the Atwood A/C units, every once in a while during the generator cycling on and off, one the of thermostats will go into E4 and I have to reset it. Kind of hard to do if I have two dogs in the coach and I'm 20 miles away working a K9 deployment with another. I need it to be reliable but right now, I don't trust it.
The only thing I don't trust anymore at this point is the Atwood units going into error now and then. Not sure how to avoid that. I wish they would come up with a thermostat that will communicate with the magnum and / or Xantrex systems... Maybe it exists but I don't know.
