08-04-2021, 05:53 PM
Mopar/TRW TPMS sensors
I had all my Factory TPMS units replaced by a Dodge dealership. 4 rear ones came in a single bag. One of them wasn't immediately working so I had an aftermarket one put in by a local tire shop, that has registered.
Pictures are of the factory unit removed.
FYI, Mopar charges $75 each. The aftermarket unit was $35. They just need to work on the same frequency. Attachment 260365
2021 (Dec) Dynamax Isata 30 FW Xplorer
08-05-2021, 06:58 AM
You have just dispelled the myth that you have to have the same factory transmitter for the system to work. good info
Retired Navy
2016 Flagstaff 26 FKWS
08-05-2021, 08:39 AM
I've run the cheap aftermarket ones in my jeep on multiple sets of wheels over the last 5 years without issue. The cost savings alone is enough to justify remounting a tire in the event one doesn't work. Though I'd probably just wait until the next change out. YMMV
2016 Dynamax DX3 - Big Blue
08-05-2021, 09:37 AM
Here's another angle photo of the factory TPMS.
08-06-2021, 08:41 AM
Norwood Auto Italia
Originally Posted by toshu
I dont see a part number on the one pictured. Should be ...22AD according to my dealer?
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
08-06-2021, 08:46 AM
Norwood Auto Italia
One case does not a myth dispel. The RAM forums are full of failed TPMS sensor examples and very few (if any) recommendations for an alternative. Even in the example here, the writer does not have a brand or a source to offer and there is a significant difference.
Its the same story with LED and Halide lamps. Literally hundred of imitating examples available on EBay but few have the endorsement by name of actual users under test conditions. Either reliability, fit or focus point, or any or all of these are variables.
And of course for most of us the failure of these TPS units is happening during the warranty.
08-06-2021, 09:33 AM
Lots of numbers on the sensor. Hence 2 photos. The first picture has a P 68455822AD visible.
WRT the aftermarket unit, although I haven't driven the vehicle much, the aftermarket sensor did connect to the vehicle. I'll know more in a week or so and can confirm its viability as well as try and get the aftermarket product that was used.
08-06-2021, 11:14 AM
Norwood Auto Italia
That is the correct P/N for the outside wheel not the inner which is ...8223AD, missed it upside down on my phone.
Looking forward to seeing the non branded part details. One thing to be mindful of is not only the ability to connect but also to stay connected as the pressure and temperature increases. Most of us seeing drop outs are because of these factors. So easy enough to connect but another story with respect to staying connected.
08-07-2021, 11:01 AM
I have had the failures you speak of starting 20 min after I left the Dealership last Decenber...it freaked me out. I put 6000 miles on before having all 6 replaced 2 weeks ago, so I have seen them all come and go..... Not to confident that we will get good results. The Tire shop owner, who also owns a new Isata 5 30FW thinks it might be the receiver unit up front and not the sensors...
08-07-2021, 01:18 PM
My guess is that the sensors are all the same.....what is different is the valve stem connected to each, since the wheels have different stems pointing in different directions.....
In my case we replaced the stems completely and put on the Borg stems and Gorilla caps.....mucho mejor!!
08-08-2021, 08:43 AM
Norwood Auto Italia
In which case that would mean that one could not have aftermarket sensors fitted because no dealer would agree to that unless you supplied them. And without the dealer's software you could not code/set up the sensors to recognize each in its position?
08-09-2021, 01:33 PM
Shrader makes universal sensors that you use a programming tool to set to your model. They work great and it’s what we are using on our tpms kit.
Unlike the aftermarket tpms systems these battery’s last years!
—john
08-09-2021, 02:31 PM
Norwood Auto Italia
—john
Interesting.
https://catalogue.schradertpms.com/e...vehicletype=AU
No availability for RAM 3500 or 5500 2020 models.
08-10-2021, 11:19 AM
The Tire shop I took them to and shared replaced one of the 6 new sensors with after market. He has the right tools to connect the sensor to the head....
At this point I dont ever plan on going to a Dodge dealership for anything related to TPMS
08-10-2021, 11:24 AM
Norwood Auto Italia
I believe you are right. Any rear end work on an I5 is not going to be possible at a RAM dealer, warranty or not. They are going to have to send it out so you might as well have a preferred supplier to throw at them when it comes to warranty and for the rest go direct.
Also I believe there are very few dealers that can do an alignment. The mind boggles that with all the trucks sold in the DFW area, no RAM dealer has that capability. They can do a 5500 but not an extended wheelbase or a loaded edition which by definition is an RV.
08-10-2021, 12:13 PM
Commercial Member
Did you try Roger Williams Chrysler Dodge? I know they have come through a few times for us.
08-10-2021, 06:19 PM
Norwood Auto Italia
Thanks Brian – not yet because they are in Weatherford which is a 200 mile round trip for me.* I did see your post at the beginning of this thread with respect to them and am keeping them “in reserve” as it were, for the yet to be needed event that requires the rear end in the air for warranty.*The challenges these dealers face is that they have never seen a long wheel base 3500/5500 package that is at or close to the GVWR.* They sell C&C and C&C with factory “approved” upfitting such as ambulances.* Until they saw my I-5, their service managers told me that they had no idea that anyone was making a RAM – RV as this has always been a Ford domain.*
08-30-2021, 11:40 AM
TPMS Range
Any on have issues OEM RAM 3500 TPMS system with 43' Trailer? I have intermittent issues due to distance from tires to receiver.
08-31-2021, 01:56 PM
So is it a TPMS sensor issue (the sending unit) or is it the receiver unit location? I have heard conflicting stories on this one.
I have three to four TPMS sensors that are either bad (they are intermittent, sometimes they work and sometimes they don't) or the receiver is not getting good connection due to interference...
Thanks,
DK
2021 Dynamax Isata 5 30FW Xplorer
08-31-2021, 02:07 PM
Commercial Member
Ram tried to claim at one time it was because we stretch the chassis. If that was the case however, we would see a higher rate of failure on the 34DS which is the longest stretch....and we do not. it seems to affect them all about the same rate and we have even seen it on raw chassis. So blows that theory out of the water.
