Originally Posted by dannko
So does the multiplex panel have a little gremlin inside and turn all the lights on and off just to mess with your head? I thought it was supposed to hold the memory of previous setting when MASTER LIGHTS is turned on and off?
OH and that MASTER LIGHTS switch by the master bed in the I5 35DB should not be right by your elbow/arm.
Apologies if this was posted but I did the search and found nothing.
If you PRESS AND HOLD the master light switch it will turn ALL lights ON or ALL lights OFF. And it wipes the memory.
If you adjust all the lights and just "TAP" the master switch, it should turn them all on or off to their last setting. But I think if all power gets cut to the system this is not going to hold as it is a temporary setting.
I found when coming back to the unit after moving sites, I end up pushing and holding the mast switch when we got back to turn everything on. Then we just adjusted from there.
