11-21-2020, 07:07 AM
Multiplex wiring.
I want to pull 12 volt power to some usb wall plugs. Since I’m not familiar with multiplex lighting systems, I’m wondering if I can safely pull power from the light switches.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
11-21-2020, 08:53 AM
I never pull power off a light switch I go to the source and tap in there this stops any dimming or flickering as things stop and start. No sure I understand multiplex lighting system are you talking about 12V and 110v on the same panel or on the same switch? if so a multimeter will identify the circuits for you.
Retired Navy
2016 Flagstaff 26 FKWS
11-21-2020, 09:07 AM
Sorry I should have said I’m looking for information from Greg at Dynamax, or someone with experience with older Dynaquest RVs.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
11-21-2020, 10:20 AM
Are the older ones even multiplexed? I thought that was a more recent addition.
2016 Dynamax DX3 - Big Blue
11-21-2020, 10:27 AM
It’s not like the newer ones with a touch screen but I do believe it’s a multiplex system though. I could be wrong. I was wrong once before a few years ago.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
11-21-2020, 10:41 AM
I can tell you with certainty my 2016 DX3 is not multiplexed. The Freightliner portion is but not the dynamax. Just good ol fashioned 12v wiring. If you don't have a panel I'd imagine you're in the same boat.
As to whether pulling power off a light circuit is a good idea, if its just a USB outlet pulling 2A im sure you're OK. Id still look at wire size and fuse accordingly but I don't think you're going to get any adverse behavior. If you've got a thick wire though a small distribution block with fuses could be a cleaner solution if you're going to need power in that area for anything else.
11-21-2020, 11:00 AM
Dynamax calls it Intellitec multiplex lighting system.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
11-21-2020, 11:17 AM
Hmm not heard that term before. But I haven't really dug into the lighting circuits either so I may be mistaken there.
11-21-2020, 11:27 AM
Commercial Member
The old ones are multiplexed using Intellitec. Greg would have to chime in on where to tap...best bet is to avoid the lighting of course and get a constant hot.
Most of the time, with multiplex, the wires going to the switches are "signal wires" and not power wires. The power would run directly to the appliance.
11-21-2020, 01:17 PM
So your saying the the hot and ground go directly to the lamp itself, maybe?
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
11-22-2020, 11:01 AM
Since the lamps are powered by the Intellitic control unit that is under the dinette seat & are dimmable you cannot pull power from the lamp itself. The switches are request signals to the controller to turn the lamp on at the set dimmer setting.
David & Mary Button - Ithaca NY
2011 Dynaquest XL 36' Freightliner
Cummins ISC 330HP/1000TQ
11-22-2020, 12:00 PM
Got it, thanks. I’ve decided to run a dedicated line to the USB’s. I’ll probably pull power from the battery bay.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
11-22-2020, 02:03 PM
Since you are going directly to the battery, you might consider putting a power distribution fuse block in the bay and then run everything you need off the block and have each run fuse protected. There are a number of them on Amazon, this is a six terminal block.
https://www.amazon.com/Kohree-Waterp...6071610&sr=8-4
2021 Isata 5 30FW
2014 Honda CR-V
11-22-2020, 02:29 PM
Good idea, thanks.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
