Old 09-03-2024, 07:21 PM   #1
Musings from my first few trips
This is my first post in this forum.
After 6 years of camping with Airstream travel trailers, we recently jumped to a Freightliner-based Dynamax. In a few short trips over the last month, I've noted some poor quality issues, one or two "interesting" design choices, and a few mind-boggling artifacts. We love the coach, so I'm not complaining here; I'm merely noting a few things to get some feedback on. Perhaps my take is incorrect on a few of these things, but here's my unvarnished reflections.
The small cabinet behind and above the driver seat contains the control panels for the 3 slides. It is quite nice that they added a strip of LED lights. However, they put the strip on the front-side, so opening the cabinet when the slide is closed results in 1.21GW of retina-destroying light hitting my eyeballs. If anybody at Dynamax comes across this post, they might want to consider putting the LED strip along the rear side of the cabinet--you'll still get the light but you won't blind the operator.
I have tried to use the XM radio, but I keep getting and error message that says the antenna is not connected. I'm not interested in tearing apart the dash to find the missing connection, but I can't help but wonder how that ever got through QC.
Speaking of the radio head unit...I really like the RV-specific GPS--when it's working. At times, there is some malfunction where the unit thinks I'm hundreds of yards (or a few miles) away from where I really am. The directions go crazy trying to get me back to the instructed path, even though I'm already there. Sometimes this problem lasts for a few minutes, sometimes it lasts for hundreds of miles. Eventually it corrects itself and it shows my correct location. Has anybody else seen anything like this? What could be throwing off the GPS signal?
The worst thing I've found is the fuel gauge. This thing is as reliable as one of the Magic 8 balls we had when we were kids--and it's just as consistent. When I bought the coach, I was somewhat disappointed that they only gave me 1/4 tank of fuel. I filled up the tanks as soon as I departed the dealership, but I could only fit 36 gallons of fuel between the 2 tanks. On our first camping trip, the I let the tank go down to less than 1/4 tank. I filled both sides to the absolute top where I could see the top of the fuel level. The pump read 42 gallons total. This past weekend, same thing. 1/4 tank remaining, and it will only take 41 gallons until the fuel is at the top of the tank. Oh year, I forgot to mention, when both tanks are absolutely filled to the brim, the full gauge reads somewhere around 3/4 full. Can this be fixed? is this a Duramax problem or a Freightliner problem? If the generator stops pulling fuel at 1/4 tank, does that mean that it will stop running even though I probably have 60 gallons of fuel left?
Here's one for the inconvenient but fixable category. When I had the RV welding shop set up the flat-tow arrangement for my Bronco, they found that the 7-way trailer plug was missing any signal for running lights. Everything else worked. They were able to pull a wire from somewhere to fix the missing signal, but this defies logic. It appears that the wire for running lights was never added to the 7-way plug.
We're loving the bed and the theater seats. These things are as comfortable as one would hope. The air-ride driver and passenger seats are next-level bougie. After years of absorption fridges, we're digging the size and features of the residential unit. My wife and I can now pack enough food so we don't have to restock to keep our 2 teenagers from dying of hunger on the trip. We have tried to outlast the Aquahot water heater, but it wins every time. Nary a cold shower in the joint. With every other RV we bought, we would find lots of nuts and bolts and light fixtures and other mystery parts on the floor after each leg of the journey for the first 6 months. In the DX3, nothing has rattled loose in the first 2500 miles.
Anyone else experienced any of these things? Let me know what I'm getting wrong here. Thanks, everyone, for your support.
~Jayson
2024 Dynamax DX3 37TS
Blackout Xplorer
JayBauman is offline   Reply With Quote
Old 09-03-2024, 09:21 PM   #2
I'm sure you paid plenty for it so I would not expect loose and falling nuts and bolts!
2017 Wolfpack 315 Pack 12 5th wheel Toy Hauler
2013 F250 6.7 Diesel Dually 4x4
Odyknuck is offline   Reply With Quote
Old 09-04-2024, 07:20 AM   #3
halla's Avatar
So XM Radio is most likely the connection to the Sirius XM box, mine is behind the passenger side dash, pretty easy to remove, there is a chance it just vibrated loose.
The Radio GPS is most likely the GPS antenna, small block hooked to a wire, it is supposed to be mounted ontop of the dash, center right against the windshield, sometimes they dont get put in the right place, or they were not stuck down with the tape and fall under the dash causing the issues. (There are a few posts on this forum about this already).
There are hundreds of posts about the fuel gauge, do some searching and you will find them. We have had three Dynamax units, none of the fuel gauges are accurate, a known Freightliner problem. I always make sure I fill the passenger side first and that seems to help. I also bought a diesel scan gauge, I use (miles to empty) and when it is 180-200 miles to go, I fill up, the empty light has been on for hours at that point.
Glad you are happy with everything else. Enjoy and welcome to the family.
Aaron
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
halla is offline   Reply With Quote
Old 09-04-2024, 06:48 PM   #4
Commercial Member
I think I already mentioned the LED light to production.
What is interesting, is I felt the wet bay light was in my face, so on ALL compartments we started mounting an LED strip, above the cargo door shining in. We also started dropping the front cabinets styles 1/2", to do the same. It might just be 2025 model year. Not sure when we completed the change.
GPS: my phone does the same thing. I am not sure why it is so far off, but with the overhand of the RV, I was wondering. Or maybe the metal framed shell??? It was weird on my rally trip, could never figure out why.
Glad to hear it on the nuts and bolts.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (Do Not Ask in a PM) so others can benefit from the answers.
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 09-04-2024, 09:39 PM   #5
Retired
Regarding your diesel generator question: That has nothing to do with the fuel gauge, so it is not affected by inaccurate gauge readings. The gen draws from the driver's side fuel tank, and the pickup is mounted at a height where it will stop drawing fuel at a certain point, supposedly when there is about 1/4 tank left, but I'm not sure how accurate that is. Same thing for the aqua hot, but on the passenger side tank.
Tucson Steve is offline   Reply With Quote
Old 09-04-2024, 10:02 PM   #6
roonabeck's Avatar
For sure, the generator and aqua hot both continue to work fine when the freightliner gauge reads below 1/4. They still work when my refill takes 70 gallons of fuel. Not sure how few gallons have to be left in the tanks when one or the other might actually stop working.
To get my gauge to read all the way full, I have to top off the tanks until fuel is sitting in the filler neck.
2019 DX3 Bunkhouse
2015 Thor Four Winds 26A (sold 9/2022)
roonabeck is offline   Reply With Quote
Old 09-05-2024, 12:26 PM   #7
Commercial Member
It is neither a Dynamax issue or really a Freightliner issue. They just have a HUGE reserve tank, so you do not get stranded running out of fuel I assume.
I think some of it might be that the tanks are 100 gallons, but where the fill is (not at the very top), it has a built in air gap at the top for expansion, that is likely more than the 10% required.
Then, the way the fuel pick up is....it's just a float mounted at the top of the tank. By giving us fuel take offs, it raises that pick up about 1/2".
For me...when the light comes on, I am ready to stretch my legs anyway.
Old 09-06-2024, 02:25 PM   #8
That's always the plan for us. Everyone else is able to stand up and stretch for a moment when we're on the road. Not so easy for me, since I'm the only driver. (On an related note...anyone have a good plan for convincing my wife to learn to drive this beast?)
I'm more concerned when we go to places like western Wyoming where truck stops that accept my Open Roads account are few and far in between. Heck, people are few and far in between in that part of the country! I'd like to know how much fuel I really have in the tanks in that situation.
I think a ScanGauge, or something of that ilk, might be the simplest mitigation.
~Jayson
Blackout Xplorer
Old 09-06-2024, 06:14 PM   #9
MVD
I had a retinal tear outside of Austin, Texas in April when we were in our way back home to Carlsbad, CA. My wife had only driven our previous Sprinter based coach about 200 miles in the 8 years and 70,000 miles we owned it. She learned quickly, out of necessity, and drove 1,600 miles home (mostly I-10). We have logged about 4,000 miles in the past 33 days on our current 15,000 mile adventure. She hasn’t driven yet on this trip (and probably won’t), but she is now confident she can if necessary.
Mark and Victoria and Princess Charlotte
Aka “Charlie” Chesapeake Bay Retriever
2024 Dynamax Europa 32KD Explorer Dark
2018 Jeep Wrangler JLUS
2016 LTV Unity MB
2002 Pace Arrow 36
MVD is offline   Reply With Quote
Old 09-07-2024, 10:11 AM   #10
malmz's Avatar
I have been researching the scangauge d and am considering it for DTE. It appears when you fill up you set the full total gallons and somebody said to enter 90 gallons for the 10% factor. From there it pulls consumption from the computer and determines remaining fuel.
Correct me if that is not accurate.
Based on that, if you are running the genny at all while parked or driving down the road for coach AC, that would completely throw off the remaining gallons and DTE. Any personal experience here?
Who installs the take off spacer at the sender, freightliner or the chassis unfiltered? When that is done is the sender adjusted at all? 1/2" can be a big difference on a swinging sender arm. I wonder if anybody has tried a linear sending unit, we used to build those into diesel cleaning machine tanks years ago.
malmz is offline   Reply With Quote
Old 09-07-2024, 10:48 AM   #11
malmz's Avatar
I am going to add to my own thoughts. When I search for M2 106 sending units, both rod and linear sending units come up. I am assuming we have rod based on responses. When does Freightliner use each style? I may see a reference to linear on rectangular tanks, but not entirely sure. I will look more when I am behind a computer.
Steve
2024 Dynamax 32KD Xplorer with Std Quick Silver paint
that M4LED guy
