LOW hours on the generator ?
if it is still quiet new and hardly broken in .......will make it harder to start as well
especially in the cold weather
run the generator more to make sure it is fully broken in
it may then get better at starting the air conditioner
The drain on the battery @ 2 amps
will eventually flatten the batteries ...
sounds like it already turned itself off before
it will restart itself when a good charge voltage is applied
The battery sounds like it needs a good charge up ... plug into shore power (even 20amp cord)
OR run the generator for a few hours ... it would probably do the generator some good....
either have some sort of trickle charge or disconnect battery cable while storing
Tarpon Springs FL
2022 Salem 24RLXL
