Originally Posted by Orangecrush
Can you be more specific? 😂
Can I jump it?
Looking closely at your picture it appears you have no power to the BIRD unit.
There should be a green led lit up on it.
Check the inline fuse that is buried in that cable mess on the electrical bay floor.
May be blown.
This fuse is also on the sense line for the AGS unit which should have a red LED lit.
If you have a meter. Check both sides of the large solenoid heavy cables to ground. Both should have battery voltage there. 1 side is coach other is chassis.
With the generator running you should have charging voltages on those cables.
Hopefully you will have something better than 12volts on at least one side.
While genset is running hold the Boost button and try to start the truck engine. Again hope this starts. If so get to a repair shop or home.
If not, might have to call mobile services.
Good luck.
Ken
