Just a word of warning, when using balancing beads. Wear eye protection when removing valve cores. The beads can blow out of the stem at enough force to cause eye damage. Also the beads become charged with static electricity while moving and stick to the tire surface even in the 10:00 - 2:00 position. If the tires get filled with air that is wet, it will cause the beads to clump after the RV sits for more than a couple of weeks. The clumping beads will self balance again after several miles of use, but might feel like unbalanced tires for the first few miles. I used them in my DQ320 and was happy with them, but had a couple of valve stem issues that were resolved with a quick blast of air into the tire. I believe my next coach will have Centramatic balancers instead of beads.
Currently "in between" Dynamax's. Looking for a good DX3 or Force.
