No bugs for my Fresh Water Tank
I have located the overflow/vent lines from my fresh water tank. One of the 1/2" lines already had a valve? The other is about to get one to keep water from pouring out while I drive. I have labeled the Add Water Valve to remind me to open the overflow valve when filling my fresh water tank.
The big 1 3/8 line is getting a filter of sorts. These are normally put over air filters found on small motorcycles. I had a few not in use. Should keep most critters out and the two closed valves will keep the smaller hoses clean and bug free.
2022 DynaQuest XL 3400KD CabOver, WD, Lithium Batteries, 4 190Watt Rigid Panels, extra inverter for AC operation w/o Genset.
