12-03-2022, 11:12 PM
No power to GFI plugs
We are on a 50a RV spot and when we run on generator we aren’t getting power to our plugs. We are in a 2023 Dynamic Isata 5 28ss and despite many of the plugs having a GFI sticker on them … none have the GFI reset button. Any ideas on what might be causing the issue? Tried resetting breakers, no fuses blown. No idea if there is a master GFI reset button somewhere
Thanks all
Oliver
12-04-2022, 12:04 AM
Originally Posted by OllieRob
We are on a 50a RV spot and when we run on generator we aren’t getting power to our plugs. We are in a 2023 Dynamic Isata 5 28ss and despite many of the plugs having a GFI sticker on them … none have the GFI reset button. Any ideas on what might be causing the issue? Tried resetting breakers, no fuses blown. No idea if there is a master GFI reset button somewhere .
Thanks all
Oliver
Most GFI outlets with reset button are in bathroom near sink. May also be in the wet bay (if you have one).
2004 Nissan Titan
12-04-2022, 12:14 AM
I'm confused. Your in a 50a spot and you're running on your generator? Is your rig 30a or 50a?
Does this problem happen when you're plugged in?
Welcome to the forum!
2015 Dynamax REV 24TB class C
12-04-2022, 07:46 AM
Hopefully someone with a similar rig will see this and tell you where the outlet with the reset button is located! It IS there somewhere!!
Peace!
Dan & Rita D
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41, 2021-49, 2022-43
12-04-2022, 08:39 AM
Thanks all
Oliver
Reading this sentence makes me believe that when using shore power, everything is OK... is that correct?
If so it sounds like you have a generator electrical supply issue and not an outlet or GFCI issue.
Your rig has what's called a transfer switch that transfers the electricity from either shore power to to the generator and your generator has a circuit breaker on it to protect from overloading the circuits. These items both come into play when using the generator.
I would start by looking at these two things. Just a note: it has been often documented that on certain models of generators, the circuit breaker can be hard to see and reset.
If your outlets don't work on shore power, then the advice to find and reset the GFCI are valid.
Days Camped: '18=48 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=112 ☼ '23=32
12-04-2022, 09:38 AM
Norwood Auto Italia
Its on the 120v panel as others have written. I have the same rig and I can run the generator and shore power simultaneously and often do before I disconnect shore power. This is necessary because I do not have the uprated I/C that would handle both ACs for a short period.
However I have been warned and concede that quality of the Transfer switch is not what I am used to on my 2006 Renegade and its probably going to fail if I do this often. I do it all the time ion the Renegade (10 years) and also on the Born Free (7 years) so the likelihood of failure is the continuing reduction in component quality by the Chinese manufacturer.
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
12-04-2022, 12:43 PM
Have you checked the circuit breakers on the generator?
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
12-04-2022, 03:50 PM
Phat Phrog Stunt Crew
Do you have a surge protector in line? Some generators have a floating ground that doesn't allow the power thru the surge protector into the rv. If this is the cause you need a dummy plug with the white common wire and ground wire tied together.
2014 Wildcat 327ck
12-05-2022, 10:11 AM
Commercial Member
^^^^this^^^^
If "Search this Forum" does not yield an answer, please post questions as a "New Thread" (instead of sending a private message) so that others can benefit from the answers. Use Private Messages for sensitive information only.
Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
12-05-2022, 10:31 AM
NO GFCI reset but has sticker...
means there is a main GFCI protecting every outlet
can be at the panel OR the first outlet is the main and will have a reset
generator ... not sure you can investigate if your generator is bonded and causing the GFCI to read a neutral imbalance
https://www.google.com/search?client...e+gfci+breaker
Tarpon Springs FL
2022 Salem 24RLXL
12-09-2022, 09:48 AM
You probably have GFCI circuit breakers. Check your circuit breaker panel. The circuit breaker is the reset.
2021 Force 37TS (Detroit DD8)
2021 Jeep Grand Cherokee Trailhawk
2020 Isata-5 36DS (traded in)
12-09-2022, 10:14 AM
It appears that Ollie only visited the site on that one day. 12/3 Hopefully they figured it out and are enjoying their new rig!
Peace!
Dan & Rita D
12-09-2022, 03:02 PM
Commercial Member
lol....came here just to say the same thing. We are troubleshooting with ourselves at this point.
12-09-2022, 04:29 PM
