Old 03-26-2024, 04:17 PM   #1
No Power to my Co/Propane Detector
2022 Isata5 30FW Explorer package
My CO/Propane detector is not getting power. Fuse is good and Iíve checked the function of the detector and it works. The wire that leaves the fuse box is red/black, but when it appears at the detector, itís solid red. Is this circuit shared with another device or circuit that might have a bad connection ? I would think it would be a dedicated circuit.
I've searched the file section but cannot locate a wiring diagram for the 30FW
Can someone point me in the right direction? TIA !
Grezdlitn is offline   Reply With Quote
Old 03-27-2024, 12:02 PM   #2
KRedburn's Avatar
usually the CO/Gas detector unit is direct wired to the house batteries.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 03-27-2024, 12:22 PM   #3
On my trailer the CO monitor is fed from the fuse panel. The 15A (PUMP) circuit feeds my water pump, water heater, CO monitor and the convenience center panel.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is online now   Reply With Quote
Old 03-27-2024, 12:37 PM   #4
Flybob's Avatar
If your radio is nearby it may be on the same circuit as they both remain powered usually directly from the battery via an inline fuse.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-27-2024, 08:34 PM   #5
No joy !
On everyoneís advice I traced the coach battery feed all the way to the disconnect. There are four blade fuses all showing to be good. Two 5 amps, one 15 and a twenty. I have no idea yet what they feed but all show to be hot. My 12 volt distribution panel has leds that turn red when a fuse is blown. All good there. Itís been a little to cool to spend a lot of time underneath tracing wires but Iím determined to find the faulty connection. Thanks for the replyís !
Old 03-28-2024, 06:47 AM   #6
Flybob's Avatar
Originally Posted by Grezdlitn View Post
My 12 volt distribution panel has leds that turn red when a fuse is blown. All good there. !
Just a quick note, The LEDs will only turn on if the fuse is blown and something in the circuit is turned on. This is not the case for your detector as it is always on when connected.
TST Tire Monitors
2 100W solar panels
Old 03-28-2024, 07:18 AM   #7
KyDan's Avatar
>What Bob said!
Pull the fuses and check with a continuity checker or ohm meter. The LED
indicators do not always show a bad fuse!!
Peace!
Dan & Rita D
no power, power, propane
