Took my 2019 Isata 3 to MB, they could not fix running light issue because it’s deals with the connection between the chassis and the box (not sure of the correct terminology). Does anyone know where the connection of the running lights on the chassis connect to the box? Help!!
There are several threads on this. Just heading out, but if you search for "Hopkins controller" you are bound to find several. The controller is located in the middle of the chassis, up near the rear bumper...between the two frame rails as I recall.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Replace that bad relay with a new relay. Had the exact same issue, glad you found the relay. After I replaced my relay, I did not mount the relay upside down in the wire bundle.
I did put a little bit of silicone on outside relay socket when I inserted the new relay.
Wouldnt hurt to put some dielectric grease on the prongs before you plug it back in, will help with moisture down the road, and hhl had it right, mount it so the lettering is facing to the top.
I called Dynamax parts department for replacement.
You should be able to get one at any auto parts store. Just make sure the schematic on the cover matches the new one.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
I’d like to thank all those in the forum for the help. I ended up going to Auto Zone and found a match. Mounted it upside down and used placed silicone around the wires and cap. Thanks again Dennis
