Old 08-02-2020, 02:24 PM   #1
Our best Isata 3 upgrades so far
We have a 2017 RW. We put dimmers on most of the light switches and added improved speakers inside. We then put Michelin Agilis all around which made a nice improvement in the ride. This weekend we changed the Anderson 200RV plastic valve to the Anderson MAN101RV-RF all brass valve. Today we switched out the rear shocks for Bilsteins, which has been the best improvement to date!
Don't feel too many more upgrades are necessary. The previous owner had Mercedes tune the engine to give it more torque and HP. Love our Isata 3!
Kimjim is offline   Reply With Quote
Old 08-02-2020, 04:26 PM   #2
Oh, forgot two more important ones. Built a stairwell cover so the dogs have more space while traveling and replaced the door seal. The new door seal really cut down on wind noise.
Old 08-02-2020, 05:52 PM   #3
Mercedes will tune the Sprinter's engine for more torque and HP? Do you have any details on that? Is this the 3 liter V6? What is the horsepower output after the tune? Is it now more than 188 HP?
BehindBars is offline   Reply With Quote
Old 08-02-2020, 06:11 PM   #4
75 more HP and 95 more torque
Old 08-02-2020, 06:13 PM   #5
Sorry, hit reply too soon. Yes, 2016 Mercedes Sprinter 3500 3.0 V6. Now has 263 hp
Old 08-03-2020, 01:14 PM   #6
More HP For Mercedes V6
Can your shop provide details of the tuning changes to get more HP and Torque from the Mercedes Turbo Diesel? How did the changes effect the mileage you were getting? Do the changes comply with EPA and CARB requirements?
The2002Wanderer is offline   Reply With Quote
Old 08-03-2020, 01:58 PM   #7
The prior owner had it done at the factory prior to delivery. Yes it complies with all regs but I donít have any more info.
Old 08-03-2020, 02:42 PM   #8
mlmay12's Avatar
I did the door seal change and it does make a huge reduction in noise. I am thinking about the Bilsteins soon. I have done a ton of changes to my 2016, so far the best is the Lithium Batteries, Lithium PD Converter, Li-BIM 225, 2 more solar panels, 2K Invertor and Victron BMV-712 Monitor. Gotta have control of the power. Also just put on six Michelin XPS Rib Tires and a TST-507 RV TPMS.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Labs Buddy Biscuit Eater, Mr. Jake (RIP), Casey Girl (RIP)
USN-RET/DOD-RET
mlmay12 is offline   Reply With Quote
Old 08-03-2020, 02:45 PM   #9
Very nice (and expensive) upgrades!
Old 08-03-2020, 03:00 PM   #10
Velvet Fog's Avatar
This is kind of spendy, but Renntech is an established tuner who's products have a good reputation on other Mercedes. I'm waiting until the engine warranty is up before I install one.
265 hp and 422 tq.
https://www.renntechmercedes.com/ind...u-om642-detail
Velvet Fog is offline   Reply With Quote
Old 08-03-2020, 04:06 PM   #11
jneum525's Avatar
265 hp and 422 tq.
Wow. Impressive performance gains. Any idea how it impacts mileage?
2017 Isata 3 FW (Purchased 2-20)
jneum525 is offline   Reply With Quote
Old 08-03-2020, 04:09 PM   #12
jneum525's Avatar
... and replaced the door seal. The new door seal really cut down on wind noise.
What/where did you use for the new door seal?
Old 08-03-2020, 04:41 PM   #13
mlmay12's Avatar
I used this from Amazon. Removed old seal, cleaned and applied this in its place.
Trim-Lok Rubber Seal EPDM Closed Cell Sponge Rubber with BT (3M) High Strength Tape System, D Shape, Height 0.562 inch, Width 0.75 inch, Length 250 fe
Very good stuff.
2016 Jeep Willys JK
USN-RET/DOD-RET
Old 08-03-2020, 05:24 PM   #14
I used the same.
Old 08-03-2020, 05:41 PM   #15
mlmay12's Avatar
I used the same.
Great minds think alike
2016 Jeep Willys JK
USN-RET/DOD-RET
Old 08-03-2020, 06:01 PM   #16
jneum525's Avatar
Very good stuff.
Thank you both... Curious if you used one consecutive piece wrapping around the corners or did you cut each side on a 45 at the corners? ordering now...
PS: I too installed the Bilsteins. Great improvement. Especially for under $200.
Old 08-03-2020, 07:23 PM   #17
Velvet Fog's Avatar
No idea, but I'm sure it's less.
Old 08-03-2020, 07:26 PM   #18
mlmay12's Avatar
Ran it around the corners but cut and ended it at hinges, continuing on other side of each hinge.
2016 Jeep Willys JK
USN-RET/DOD-RET
Old 08-03-2020, 07:31 PM   #19
mlmay12's Avatar
Do you have the part number handy?
2016 Jeep Willys JK
USN-RET/DOD-RET
Old 08-03-2020, 07:45 PM   #20
Door seal
We took off the door completely to install it. Think we mostly did it in once piece but can't quite recall as it's been a year. Here it is on Amazon:
https://www.amazon.com/Trim-Lok-D-Sh...p?ie=UTF8&th=1
This is for the 25 ft length which is plenty.
upgrade
