Old 06-09-2024, 04:52 PM   #1
Power outage at eastern rally
Last day of Eastern rally and sitting in RV (2018 Isata 3). Heard a very loud pop and could smell burnt electric "something". Figured this was not good.
Turns out entire city without power.
Surprisingly, when power came back, everything seems fine. A/C works. TV works. Microwave works.
Can anyone think of something else that might have made sound or smell?
NearDenver is offline   Reply With Quote
Old 06-09-2024, 04:56 PM   #2
wmtire's Avatar
That sounds like possibly the capacitors in the converter. All your 120 volt AC stuff will work without a converter BUT if it's smoked all of your 12 volt DC stuff is currently ONLY getting power from the batteries which will eventually discharge and they will not function.........your thermostat to your air conditioner is usually 12 volt DC, so if the batteries run down, you ARE going to lose air conditioning.
2011 Flagstaff 831 RLBSS
I want to go to Bora-Bora, but Iím too Pora-Pora.
Old 06-09-2024, 04:58 PM   #3
wmtire's Avatar
See this thread, and especially the last post there for a workaround if your converter did indeed smoke.
https://www.forestriverforums.com/fo...nt-152813.html
Old 06-09-2024, 05:12 PM   #4
Deleted
chrisski is offline   Reply With Quote
Old 06-09-2024, 05:19 PM   #5
wmtire's Avatar
Originally Posted by chrisski View Post
If you want to test this prior to the battery dying, disconnect the trailer from the vehicle and disconnect the trailer battery. If the 2 volt still works, your inverter is good.
It could be anything you haven’t tried yet.
The OP has a motorhome. We are in the Dynamax subforum.
Old 06-10-2024, 03:03 PM   #6
How do you know...?
How do you know the smell wasn't from a burned-out pole transformer or the big fuses on it?
Did you notice that the OP said everything seemed to work once power was restored?
Larry
Larry-NC is offline   Reply With Quote
Old 06-10-2024, 03:18 PM   #7
wmtire's Avatar
1. I don't know which is why I said "possibly".
2, I did notice and stated "If it's (converter) smoked".......and you do know everything will work once power is restored up until the batteries run down with a non functioning converter.
It's the same things that happens when members connect 30 amp RV's to 240 volts and the converter smokes.
Old 06-10-2024, 03:28 PM   #8
Flybob's Avatar
If the converter was smoked everything would still work ( until the battery was drained).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-10-2024, 05:23 PM   #9
Umahhhh who would do this?
own up!
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is online now   Reply With Quote
Old 06-12-2024, 08:26 PM   #10
CyberShanks's Avatar
own up!
I think it's fair to say nobody would do it intentionally, but some boxes in the past have been wired wrong. I know I always check before attaching the power pole to my RV with this type of device:
https://www.amazon.com/Progressive-I.../dp/B088D2JVN4
It is cheap insurance in my perspective, have one in 50A and one in 30A.
Jim
2021 Dynamax Dynaquest XL 3400KD
2022 Aluma 8220H Tilt flatbed to carry:
2012 Jeep JKU Rubicon or slightly modded 2001 Jeep TJ
CyberShanks is offline   Reply With Quote
Old 06-12-2024, 09:37 PM   #11
I think my converter works fine. With solar I had to check at night.
Maybe it was something outside. That would be nice (for me).
Old 06-13-2024, 09:00 AM   #12
MSgt & MSgt, USAF Retired
clockcuff_66's Avatar
I also got a whiff of burnt electrical when the power outage occurred. It was in the air though, not from our rig.
Chris and Joyce
2022 DX3 37RB 'Destiny'
2015 Rubicon
2020 Ultra CVO
Traded in 2020 ISATA 5 36DS
clockcuff_66 is offline   Reply With Quote
power
