12-28-2019, 05:32 PM
Probably a dumb question... but how do you turn off the fridge?
How do you turn off the fridge on an Isata 5? Frigidaire model FFHT1621TS1
Is there a physical on/off switch located somewhere?
Thanks in advance.
-Brian
2020 Isata 5 30FW 4x4
2019 Jeep Grand Cherokee Summit
12-28-2019, 05:48 PM
Coach
The easiest way to turn it off completely is to switch off the breaker. Residential RV fridges are generally on their own breaker.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
12-28-2019, 05:52 PM
Thanks! That worked. Apparently the TV is also on the same breaker.
-Brian
12-28-2019, 06:09 PM
On mine you just turn the temperature control all the way off.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
12-28-2019, 06:25 PM
That might cut it off at the refrig but the line coming into the unit will still be hot...be careful!! I've been bit by 120 and it ain't fun!
___________________________________
2015 Brookstone 315RL
2016 GMC Sierra 3500HD Diesel 4x4 CC LB LEMON
12-28-2019, 08:11 PM
I tried that. On this model, it still operates, just at a warmer temperature.
-Brian
12-28-2019, 11:32 PM
There’s usually a socket underneath the fridge or behind a cabinet. I just unplug mine when I don’t want it on.
Bob & Amely
2022 Dynamax DX3 BD.
(Previously 2018 Dynamax DX3 BH, with a years break between)
12-29-2019, 09:49 AM
Dennis Julie Wilson
We got an extension cord with an on/off switch and fed it through the grill on the bottom and plugged the fridge in. We can now turn in on and off easily.
Dennis and Julie Wilson
12-29-2019, 01:42 PM
On my dx3 the vent below the refrigerator is where it's plugged into AC I found a remote-controlled plug from Menards pluged the fridge into the remote control and plug that into the AC has a on off remote control key fob I keep it in the top drawer in the kitchen
12-29-2019, 03:31 PM
On our Frigidaire there is a menu on the control panel on the front door that I use to turn it on and off and control other variables.
2018 DX3 37RB - 2017 Jeep GC Summit towed
12-29-2019, 03:50 PM
FWIW, I took a look at the manual in the thumb drive and it says.
Adjusting the refrigerator/freezer temperature
control to “0” turns off the compressor and
prevents the refrigerator from cooling, but
does not disconnect the power to the light
bulb and other electrical components. To
turn off power to your refrigerator, you must
unplug the power cord from the wall outlet.
This is how ours works. The compressor is off, but if the door is open the light comes on.
2019 Rubicon JLU
12-29-2019, 03:59 PM
On my Frigidaire:
Touch options on the control panel
Arrow down to power off.
Press and hold set until it shuts down.
12-29-2019, 04:00 PM
The outlet for the refrigerator is behind the wooden grill below it. I bought one of these and use the remote to turn it off at night when we are boondocking to minimize generator starts. Works great!
https://www.amazon.com/Century-Wirel...653069&sr=8-13
Tom and Becki
2018 Isata 5 30FW 4X4
12-29-2019, 05:20 PM
FWIW, I took a look at the manual in the thumb drive and it says...
Isn't actually consulting the manufacturer's manual considered cheating or unethical or something?
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
12-29-2019, 05:31 PM
Yeah. I feel really guilty.
2019 Rubicon JLU
12-30-2019, 05:22 PM
To be sure, I went to my DX3 in storage today to double check. When I turn off my fridge on the control panel, the fridge is off. Which was the OP's question. With the doors open, no lights come on. Fridge is off; I even have the rig plugged into to 20 amp circuit and I have the inverter turned off. When I open the fridge door, the panel illuminates the refrigerator Off light, so there is still power to it but it is off.
If the OP had asked how to pull all power from fridge, the only way would be to manually disconnect it from the power source. Which would eliminate any parasitic electrical draw, if that was his concern.
