Old 10-13-2020, 06:30 PM   #1
Propane shut-off Valve on Isata 5
The electric propane shut-off valve seemed to be very warm, it measures 141 degrees using an infra red thermometer. Is this normal, seems awfully hot and a huge power draw. This is with the motorhome parked and not in use. I would really appreciate any input on this issue as it is very concerning. Thanks!
NorthIdahoCamper is offline   Reply With Quote
Old 10-13-2020, 07:53 PM   #2
milkman55's Avatar
It does get warm. Any reason not to turn your power off with the battery disconnect, or are you plugged in when stored. You have the propane switch on or off when stored?
2021 Isata 5 30FW
2014 Honda CR-V
milkman55 is online now   Reply With Quote
Old 10-13-2020, 08:57 PM   #3
Thanks, we are plugged in when stored and will turn the propane off. I found some other threads on this that helped. I didn't like the answer, but I guess it is normal. Don't like the power drain, but I guess there is no way around it and keep all the safety cutoffs in place.
Old 10-13-2020, 09:00 PM   #4
milkman55's Avatar
Yeah, flip the toggle switch off and left us know if the temp of the valve changes with the toggle off. I always leave the toggle off except when we are camped and need propane.
2021 Isata 5 30FW
2014 Honda CR-V
Old 10-14-2020, 12:51 AM   #5
Send a message via Skype™ to toshu
Dang
There are so many odd nuances to this vehicle and it's use......I need to do a bloody checklist!!
toshu is offline   Reply With Quote
Old 10-14-2020, 08:21 AM   #6
Motorized GM
Originally Posted by toshu View Post
Dang
That valve is ONLY for remote fill versions as I recall.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 10-14-2020, 10:33 AM   #7
Do the new ones coming off the assembly line right now have it?
Old 10-14-2020, 10:37 AM   #8
Motorized GM
Have what? a propane valve? They always have.
IF the LP tank is not easily accessible (IE in a compartment on the outside wall) then it needs to get a remote fill and thus needs a remote shut off.) Not all floor plans have a remote fill...but I think all of the 5's might have them now. The 36DS did not, but we have changed that to the 34DS and it does I think.
Old 10-17-2020, 11:16 AM   #9
MSgt & MSgt, USAF Retired
My 2020 36DS has the remote fill along with the remote shutoff for the valve. As noted above it does get warm when energized.
Chris and Joyce
2020 Isata 5 36DS 4x4
2015 Rubicon
2020 Ultra CVO
clockcuff_66 is offline   Reply With Quote
Old 10-22-2020, 12:01 PM   #10
I was also led to believe that the electric propane shut-off valve (somehow) routed power through the propane detector inside. This was a safety measure that closes the propane valve if the alarm is triggered. Any truth to this?
2019 Dynamax Isata 5 35DB
Audi "Nardo Grey"
BLT4SPD is offline   Reply With Quote
Old 10-22-2020, 04:18 PM   #11
Motorized GM
Some of them are, yes, but most are not nowadays.
propane, valve
