Originally Posted by caseymyers
I couldn't find any info on the thumb drive about the TRC Transfer Switch. I looked online and if I understand this correctly this switch is also a Surge Protector for the whole coach? If that's true I don't need the portable one I've been using to protect the electronics in the coach?
THere are the details
TRC SURGE GUARD 41260 50 AMP 120/240 VOLT AUTOMATIC TRANSFER SWITCH WITH SURGE PROTECTION
The Surge guard 41260 Protects your RV bumper to bumper from the most damaging common electrical faults from faulty park power such as open neutral and reverse polarity. The unit ensures continuous power to your coach by monitoring shore power and automatically switching to generator power when it detects electrical issues that could impact performance of equipment in your motorhome. The 41260 provides basic surge protection of 2600 joules at 76,400 Amps and has a 1 year warranty from the manufacturer.
Free Shipping
50 Amp 120/240 60Hz
Open Neutral Protection
Reversed Polarity Protection
Multi-mode Surge Suppression
Time Delay at Power Up: (Shore Power 3-4 Sec., Generator Power 30 Sec.)
50 FLA Rated Contactors (Full inductive load rated)
Mechanical Interlocking Contactors
Electrical Interlocked Control Circuit
Black Heavy-Duty Plastic Enclosure
Rugged Construction
UL Approved ATS - full transfer switch rating, UL1008, (not general control)
Basic Surge Protection: 2600 Joules at 76,400 Amps
Dimensions: 12.75" x 8.84" x 5.21"
1 Year Warranty
Your dyanamax already has a transfer switch to go from shore power to Generator. This is only a
surge protector and
transfer switch. It only protects from high voltage spikes. You will more likely see low voltage conditions. Not and EMS. It will not protect from low voltage. Save your money and get a full EMS system unless that is what you already have.
