I have water coming out of the "city" connection when the pump is on. Seems to me there is a problem with the tank fill valve, but wondering if anyone else has come across this? Any help is appreciated.
Could be the valves are not turned properly. Or if you have the Anderson valve, maybe there is a nick in the O-ring and with the pressure in the lines it is leaking.
Have you witnessed this happening as it happened? or are you seeing water there after the fact?
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
