07-09-2018, 08:54 PM
Rear Differential
Has anyone used that differential lock yet on your DX3? I may need it come Friday. It's rained every day since I've been at my location in Fl.. I'm on grass/sand saturated in water.. errr..
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
07-09-2018, 09:24 PM
Other than trying to see if it worked, I haven't used it. When I bought my Diesel pusher, I remember telling my wife in the finance offer that my only concern was that one day we'd be stuck on 3" tall grass when it's wet.
It wasn't two weeks later we had to camp in a field and it rained and the grass wasn't even 3" tall. I had to get a tractor to pull me out.
I'm so glad I have a locker without a tag axle, it'll put more weight on the axle and with the locker, hopefully that doesn't happen again.
Let us know how it works if you need it!
Mark
07-09-2018, 11:13 PM
I have used mine. I was in a off camber situation trying to turn up hill in wet grass, the inside wheel just spun. When you lock it in apply the throttle real easy because it will take a partial revolution of the rearend to actually engage both axels. It worked perfect in my situation.
07-10-2018, 05:41 AM
Ours worked great to get us out of a situation when stuck in the sand. We were very happy to have it
Cindy & Walt
2018 DX3 36FK
2015 JKHR - toad
07-10-2018, 07:10 AM
Originally Posted by CSWVK
Ours worked great to get us out of a situation when stuck in the sand. We were very happy to have it Attachment 178935
Did you use the locker to get out of that??? If you did, I'm going to sell my Rzr and Jeep and start 4 wheeling with my DX3..LOL.
If you got out of that with just the locker, I'm a happy camper because like I said before, having to get a tractor (it took two) to pull me off of wet grass was ridiculous.
Mark
07-10-2018, 07:15 AM
Walt, if you got that out of there using the lock, I shouldn't have a problem.
-slim
07-10-2018, 07:23 AM
Mark
My Blue Bird Wanderlodge got stuck in the grass several times. I just learned to keep it on the paved or concrete sites and roads... no exceptions.
07-10-2018, 07:46 AM
Yep... live out in the middle of no where in Colorado. Have a quarter of a mile driveway with some uphill grades. Came back home after late spring snow, 5”+ on ground, locked rear end and got up no prob...
2016 Dynamax DX3 37TS
2013 Jeep Wrangler Rubicon 10th Anniversary Edition
Blue Ox Aventa LX Towbar w/ BX1134 Base Plate
RViBrake2 Auxilliary Braking System w/ TPMS
Frank and Karen Mann
07-10-2018, 07:49 AM
Holy cow. I can’t be the only one accused of off-roading my dynamax anymore!
I used mine in Feb when we got caught in a freak Iowa snowstorm that even caught the DOT off guard because the roads weren’t treated. I was not about to join the other idiots having trouble getting up the hill. Probably didn’t need it but was glad I had it
2016 Dynamax DX3 - Big Blue
07-10-2018, 09:07 AM
Was that at the River??
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
07-10-2018, 09:36 AM
Commercial Member
"no sir, we never ever use it on roads that are not improved. Even if there are potholes, we GPS around those locations"....typical response from every customer when there is an issue and you ask "well what did you do"....lol
that's an impressive picture by the way. I have driven the E450 in Canada...they don't salt the roads or bother to clear them, they just gravel them if you're lucky. Had zero issues. 4x4...who needs it.
07-10-2018, 12:42 PM
Yep, @ the River. No tow available, did some digging prep around the wheels & make shift ramps. Fired it up, hit the diff lock & out it came.
Cindy & Walt
2018 DX3 36FK
2015 JKHR - toad
07-10-2018, 01:50 PM
Well there goes my excuse for putting a lift kit and mud tires on my DX3. 🤣
Mark
07-10-2018, 03:01 PM
Mark
Get pictures...plenty of pictures [emoji12]
07-10-2018, 03:06 PM
Broken Toe
Bear in mind, DON'T LOCK THE DIFF ON THE ROAD. It will steer like a logging truck (ie: it won't steer worth a damn). I had an e-locker on my Samurai, and have one on my side-by-side. With the diff locked, your turning circle will double or even triple.
I would say, Only lock when you HAVE to, and unlock as soon as you can.
Tim
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
07-10-2018, 03:11 PM
Tim
Tim
Good advise Tim, thanks
-slim
07-10-2018, 05:59 PM
Rear Differential
Yes came in handy for us also:
07-10-2018, 06:09 PM
Wow! I didn’t work for me on a side road in WV grass and red clay, just spun all 4 tires and $325 to get winched out
179003
David & Tracy
2016 DX37TS
Greensburg, Pa
07-10-2018, 08:08 PM
179003
Ouch.....don’t think anything helps in the red clay, stuff is like glass.
07-10-2018, 08:23 PM
179003
I have a set of deflaters, they would probably have gotten you out of that predicament...you can also purchaser a single deflater, takes awhile but it works...
https://www.amazon.com/dp/B078T18YMC...c-3d674b63b869
