We own a 2017 Dynamax Isata 3 24RW. We have lost the rear lighting, brakes, running lights. We’ve checked the fuse boxes in the drivers seat, both under the dash and under the drivers seat. All seem fine. Is there a halter located under the coach and if so, where is it and what is it’s power source? Thanks.
The box in question is located in the rear drivers side of the coach,it will be zip tied to the frame rail,please contact our parts department and we will send you the replacement.
Thank you for the information. I sent an email Monday, 2/10/2020 to dynamax-service@forestriverinc.com and have not heard from anyone. I also have a call to the Customer Service Rep. yesterday, 2/12/2020 and await a return call from her. Hopefully I will hear soon, or if you can suggest a contact I am missing, I would appreciate your help. Thank you.
Kudos to the parts & service people at Dynamax. Several emails and phone calls and issue is resolved. There is another fuse cluster UNDER the driver’s seat that feeds via a red wire, that serves to a back harness tied to the rear frame. Problem was in the fuse cluster under the drivers seat. No need to replace any other parts! BTW, we did note that several of the wire connections were sloppy and required new connectors and a firmer “pinch”. Hope to be on the road soon!
