Old 08-02-2021, 12:08 PM   #1
Norwood Auto Italia
Rear tow hitch lights?
I made the huge mistake of not checking these on delivery or since. Last night tried to hitch up in the dark and found the lights supplied by Dynamax do not work. The Aux switch illuminates; the wiring of the Aux connection to #1 looks solid; the fuse is not blown as presumably the Aux #1 light would not illuminate but to check the JCase fuses as installed really requires you have a spare to hand because removing it will destroy the fuse as there is only one reachable edge to grasp it.
Also checked the E-brake was applied and in P and N; with/without ignition although settings are for Battery use; and checked connections to the lights.
Is there something I am missing? Something at the back of mind says there could be a safety limiting switch somewhere that prevents you from driving with what might be termed back-up lights illuminated?
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
vlamgat is offline   Reply With Quote
Old 08-02-2021, 12:58 PM   #2
Desert Boat's Avatar
The 28ss chassis wiring diagram shows it goes straight from the aux interface under the hood to the rear cap plug, red/black, (DAB). So it should only be controlled by the settings for the aux switches. These are only momentary/latch and battery/ignition.
While I have not tried it, it appears you can leave them on while driving.
2021 Isata 5 28ss 4x2 / 2020 JLU Rubicon
Prior: 2016 Lance 1995 / Ram 1500 Eco Diesel
2012 Lance 1575 / 2015 Jeep JKU Rubicon
Desert Boat is offline   Reply With Quote
Old 08-02-2021, 01:02 PM   #3
Motorized GM
I don't know of any safety lock out, so I would not waste any time trying to get them to work in various engine/brake scenarios.
Voltage at the light?
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 08-02-2021, 01:18 PM   #4
Norwood Auto Italia
Yup, just waiting for the rain to pass but that is the next test.
Old 08-02-2021, 02:33 PM   #5
Norwood Auto Italia
No power at the lights or at the output from the dark grey Aux/upfitter outlet.
Lost the top of the fuse when I removed it so the internal connections are very visible and completely intact.
So something is withholding power from the upfitter even though the indicator light is illuminating. Possibly the upfitters have a unique grounding and I am measuring their output incorrectly when sourcing the ground from a ground on the chassis? Swapped relays with #4 but still nada.
Old 08-02-2021, 04:14 PM   #6
Motorized GM
The only other quick thing is to look at the switch programming. Make sure it is set up properly in the cluster.
Old 08-02-2021, 04:26 PM   #7
Norwood Auto Italia
That was my first thought. So reviewed the set up for all 6 Aux. #1 is definitely set at Latched and Battery as is #3, 4,5 and 6. I also checked to see if any of those were connected but only #1, and 2 by Dynamax; #3 and #6 by me.
Checked for power at the fuse, there was none so it seems something has gone wrong with the Aux #1 control but this is hard to rationalize when the indicator reliably comes on.
Old 08-03-2021, 08:55 AM   #8
Norwood Auto Italia
Now confirmed there is power at the switch at indicator light shows and at the fuse where I had previously sourced a poor ground.
So the problem lies in the Dynamax wiring between Aux 1 terminal and the lights.
Another QC issue. Makes 9 on my coach. Wonder what comes next.
Old 08-03-2021, 09:00 AM   #9
Motorized GM
I do know we were short harnesses for a while. So that line might have had to be hand strung, after it was built.
Old 08-03-2021, 12:17 PM   #10
Norwood Auto Italia
It does look like that with connectors at the front end and the rear, both looking hastily constructed with the shrink insulation unfinished. I will trace it as far as I can but at the moment I cannot verify there is power at the first one next to the Aux module so i may get lucky!
Old 08-03-2021, 04:03 PM   #11
Motorized GM
OK, I was mistaken. The harness that we were short was for the M2. The 5 series had the docking lights built into the chassis harness.
Per electrical engineer: "we make the connection for the dock lights under the hood using the dodge interface connectors (see attached). Dock light wires are in the chassis harness. Drop 88 to tail light harness connector drop 1"
Old 08-03-2021, 05:43 PM   #12
Norwood Auto Italia
Super helpful. Thanks.
Old 08-04-2021, 01:12 PM   #13
Norwood Auto Italia
Solved: The Delphi GT280 interface connector has parted (again) despite both ends of the loom being well secured to the upper tow bar with tie wraps. It seems there is no positive locking on my connector pair and they are inclined to pull apart. So I secured them together with a tie wrap and tied the looms.
I believe there is a positive lock on the Delphi connector (white tab that must be pressed inwards but mine wont shift. NBD - next night hitch (Winter Is Coming) should be a breeze.
Thank you Brian.
Old 08-04-2021, 01:19 PM   #14
Motorized GM
all's well that ends well.
Old 08-04-2021, 01:25 PM   #15
Norwood Auto Italia
I am sure I will find a use for the 40 feet of wire I bought to rewire the lights.
Oh well - projects abound!
hitch, light, tow
