Repair Adhesive
I recently had to make some minor repairs (driver error) to the fiberglass rear cap on my DX-3. I used Loctite #9460 Hysol Structural epoxy adhesive because it doesn't run or sag on vertical surfaces. I was amazed that when I squeezed it out & applied it to the crack, it just stayed there. I'm sure you can overload it & it will sag. It comes in a dual tube 50ml cartridge so you'll need a dispensing gun to mix & apply it. Every other epoxy I've used will start to run, especially when you think it's fine, & as soon as you turn your back on it, gravity very quickly takes over. Only time will tell how good the bond is, but so far I'm satisfied.
