04-21-2018, 10:34 AM
Resetting Gfi
I think I just blew a the gfi circuit breaker. I tested the other one and now can’t reset either. They are lighting up with ground fault. Anybody know what I need to do? I’m running on Gen
04-21-2018, 10:57 AM
Don't know the answer and I'm not near our unit, but I think I saw a GFI breaker on the main breaker panel in our unit at the end of the bed. Might just take a look. FWIW.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
04-21-2018, 10:58 AM
Do you have GFI breakers or GFI receptacles?
You have 2 GFI receptacles and both of them are not working? That would mean you have 2 circuits out. 1st quick test it to plug into shore power if available and see if they will reset. Is other 110 volt circuits working? With 2 GFI's tripped I suspect something wrong with the Generator supply.
04-21-2018, 11:02 AM
I have checked non gfi plugs with a tester and they show correct with ground. Not near a 120vmains. It’s works perfectly up until now. Can’t reset with no power can you?
04-21-2018, 11:06 AM
I think you should be able to RESET w/o power, but you won't be able to TEST/TRIP.
If the problem still exists, it would trip as soon as you re-apply power.
2011 Traverse LT, 3.6L, FWD
04-21-2018, 11:10 AM
Can’t reset without power. This does not make sense. It is the two breakers on the main panel.
04-21-2018, 11:17 AM
Location: Alberta - East of the Rockies, West of the Rest
You may have more than one receptacle on the one receptacle labeled "GFCI", have a look around the RV and unplug everything except the microwave, don't forget the hot water tank, TV, the fridge and receptacles outside and in the basement area.
If you have power coming from the breaker (inside the converter panel) to the GFCI receptacle and you know nothing is still plugged in then the GFCI receptacle itself may have expired which is not uncommon at all.
P.s.: You need to have power to the RV to do your tests.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
04-21-2018, 11:20 AM
You can not test or rest and GFI recptical without power. Are any of your breakers tripped?
04-21-2018, 11:30 AM
I took the basement power socket out and foun a loose connection. Reset the passenger side but cannot reset drivers side. Then suddenly the passenger side tripped. Seems like something after about 5 mins of power coming through generator?
04-21-2018, 11:33 AM
Yes, there is a problem with gen power. Are all other circuits working?
04-21-2018, 12:20 PM
Yes. Tester tell me ground is good with microwave socket.
04-21-2018, 12:58 PM
Ok I get idiot of the month. I just spent 4 hours checking everything, removing sockets, fuse box, only to find you need to push down switch then up on breaker to reset. Lesson learned. Thanks for all the advice. Everything perfect now
04-21-2018, 01:07 PM
All breakers must be turned off then back on to reset. Now the question is. What caused 2 breakers to trip in the first place?
04-21-2018, 02:46 PM
I caused the first trip with my tester. When I could not reset the first I pressed test on the second. All self inflicted
04-21-2018, 04:20 PM
See said the blind man
04-21-2018, 04:33 PM
Just as confused as you
The saying goes "I see said the blind man to the deaf man while listening to the mute".
Richard & Jill
04-21-2018, 11:27 PM
"I see," said the blind man, as he picked up his hammer and saw."
