Old 09-23-2020, 01:57 PM   #1
residential refrigerator on 2018 DX3 37 RB
Can someone help me find the water shutoff valve for the residential refrigerator on the 2018 37RB? I've looked everywhere. Our residential refrigerator is on the passenger side, between the kitchen and the middle 1/2 bath. It has an icemaker and water dispenser in the door. There is a pantry on the right side of the refrigerator, but no valve that I can find. Nothing under the countertops either. Am I missing something?
RickRene is offline   Reply With Quote
Old 09-23-2020, 02:12 PM   #2
Maybe there is no valve? Turn off the water to the rig, open the hot and cold faucet to let the pressure in the lines go. Now do your work and use a towel for any water that falls when you remove the lines.
This could be a good time to add in your own shark bite fittings and ball valves.
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
Old 09-23-2020, 02:24 PM   #3
Travler's Avatar
I think on some that it is behind the drawers to the left of the fridge. When at the factory I noticed that some valves were around the sink area. That may depend on what year it is. I would start in the two areas mentioned.
2017 Dynaquest 37RB
Travler is offline   Reply With Quote
Old 09-23-2020, 04:31 PM   #4
ci4mynewf's Avatar
On my 37 TS 2020 I have to take the wood grill/vent at the bottom off. Try that.
ci4mynewf is offline   Reply With Quote
Old 09-23-2020, 07:41 PM   #5
Same with the Dynaquest 3801TS
Abe padgett is offline   Reply With Quote
Old 09-23-2020, 08:31 PM   #6
Retired Army Paratrooper
MasterBlaster's Avatar
Pull out 2nd drawer next to fridge and remove it. You will see the valve on the backside of that compartment.
Dennis & Zoleta
Retired US Army
Force 37BHHD
MasterBlaster is offline   Reply With Quote
Old 09-24-2020, 08:56 AM   #7
Itís probably behind the drawer stack to the left of the refrigerator. Itís fastened to the back frame of the drawer stack. Not a great location if you need to winterize.
Max and Mama is offline   Reply With Quote
Old 09-24-2020, 12:05 PM   #8
Motorized GM
Have you pulled the grill below the fridge?
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 09-25-2020, 04:17 PM   #9
My 2015 Cardinal 3850RL put the shutoff valve in the basement by the water pump. it's a plastic pull/push valve
xomkid is offline   Reply With Quote
dx3, refrigerator
