Originally Posted by Delco Bobby
Correct me if I am wrong. It seems you want to run your engine while parked for long periods to charge your batteries.
That will burn up alot more gas than your generator and will be harmful to your engine.
Engine harm is a real issue on private vehicles used in commercial applications where very long idle times are common. Commercial van bodies used for ambulances and refrigerated goods must meet such requirements. Especially those branded as Professional grade like the Promaster.
Closed Loop Fuel injection, oversized radiators, and electric fans are used to overcome heat buildup problems common in private vehicles not accustomed to loitering about on 24 hr shifts.
That said I have no intention of idling my engine for hours on end!
But it is an important need given the REV 24's high overnight parasitic loads which can take more than 50% from the battery even when running the fridge on propane, as so many have reported.
That combination of small battery capacity and high overnight draw makes it hard to make it from 8pm to 10am on the REV 24s batteries alone!
I tend to be a polite neighbor so running the REV 24's mind numbing Genset before 10am to minimize battery damage is a social no no!
My goal is simple:
- Run the vehicle engine for 40 min to hold my batteries over at > 50% charge while I get my coffee and breakfast made without reducing the life of my batteries or making myself the camp pariah.
- Add at least one more 100Ah battery and high idle to encourage the alternator to put 80 to 100Ah back into the 3 batteries in that 40 min.
- Add 500W or more of solar panels to keep the batteries charged in peaceful bliss during the day.
- Run the mind numbing Genset when I need the AC while boondocking or tailgating with the wildbunch.
None of these incremental changes are expensive. Initially, I will just idle the engine longer to make up for low Idle charge rates until I install the high idle kit.
Adding solar is more for my own sanity while boondocking since I did not drive into the wilderness to hear my own or anybody else's mind numbing Genset ;-)
After all some of the best places to camp don't have AC plugs or allow Genset's at any time during the day!
-PanAmMan
