Originally Posted by bclemens
Start at the top of the list above as a good beginning.
1. Tire pressure is good based on load?
2. Have you actually done a 4 corner weight to check the load? If you are "rear" heavy, it will be light on the front and that will for SURE cause issues sway and wandering.
3. If not, get a 4 corner weight, adjust redistribute load as necessary and go back to step 1.
4. Alignment?
5. Only then would I look at any after market enhancements.
All of the above.
Mine is rock stable up to 90mph or so. If very gusty windy or turbulence from some trucks I may have to keep it under 65mph. Lots of turbulence Behind some tractor trailers, if so I drop back or change lanes.
I have driven through HUGE rain storms and the stability was amazing.
There must be something amiss with your particular vehicle. You may need to take it to a Dodge dealer to inspect the chassis.
Please tell us your tire pressures.
Based on occasional wheel spin I am light in front but still handle well. I have made quick turns that no one should do in a motorhome with no ill consequences other than chastising myself afterwards.
