Old 10-21-2020, 01:18 PM   #1
Bill Davis's Avatar
Roof maintenance
What is the procedure for maintaining the Dycor sealants on the roof. No leaks, just want to make sure none start. Can you just add a coat over the old or does the old have to be removed First.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
Bill Davis is offline   Reply With Quote
Old 10-21-2020, 02:00 PM   #2
Just as confused as you
Scrapper's Avatar
Use EternaBond Tape over the Dicor sealant, if done correctly you will never have to worry about it for another 10 years. Clean the dicor and adjacent area with mineral spirits on a rag, wipe down with rag and denatured alcohol, lay down the tape doing a foot or so at a time, roll it down with a seam roller to insure good bonding. Full instructions are in the Library section of the forum under Awnings, Roofs and Exterior
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Scrapper is online now   Reply With Quote
Old 10-22-2020, 10:18 AM   #3
FOURWHL's Avatar
From talking to Greg, they just seal over the existing. I'm sure there is a limit on how far you want to go, but a couple of times you should be fine if you just want to touch things up. Definitely better than nothing at all I'd think.
2016 Dynamax DX3 - Big Blue
https://fourwhl.com - Traveling the country in our DX3 for the next year
FOURWHL is offline   Reply With Quote
Old 10-22-2020, 10:35 AM   #4
X2 for the Externabond tape. Great stuff! Best deals from Ebay or Amazon. I buy it by 4 inch wide X 50 foot long. Be sure to clean the surface really good before installing as Scrapper said. If you don't have any leaks use it anyway to seal all seams and you won't have to worry about leaks. I have used it on my patio roof also.
Wattsworld is offline   Reply With Quote
Old 10-22-2020, 12:36 PM   #5
Dynamax - Warranty, Parts
ddobecki's Avatar
Sealant Maintenance
For sealant you will want to inspect, touch up and or replace as needed every six months.
Cracks, gaps and voids you can touch up by applying new sealant over the old. Make sure to clean the area prior to application of the sealant with 98% or better isopropyl alcohol. This will give you a clean surface free of residue that normal cleaning product may leave behind for the best possible bond.
If an area is pealing you will want to remove anything loose completely and follow up with rubbing alcohol before applying the new sealant.
The same is true for the caulk on all of the exterior moldings and seams below the roof line.
ddobecki is offline   Reply With Quote
Old 10-28-2020, 08:22 PM   #6
Love my Rev
if you are talking the " water type " sealant for a rubber type roof / just clean with mild dish soap and then put on using a floor sponge mop , but dont let it run over the sides. , very easy
steve32409 is offline   Reply With Quote
maintenance, roo, roof
