are you sure? why would a 'breaker' be in the Inverter bay? Breakers are only in your Main Panel inside the coach, though other 'fuses' could be in the Inverter bay, and some, like on the Inverter itself, simply 'pop out'...pushing them back in resets them.
Another type of 'fuse' is the battery Buss Breakers, which carry large amounts of current from the batteries.
'mini-breakers', also called 'tandem breakers', are in the main panel.
The Turners...
