On my 2018 DX3 the in-motion SAT came configured for use with Direct TV. We use Dish which required getting on the RV roof, removing the in-motion dome and changing one jumper. Super easy to do and only takes 15-20 minutes, just remove the 4 screws on the dome, take it off, change the jumper setting and re-install dome. Winegard support emailed the instruction to us with easy to follow pictures.
You should not require any other special equipment except for the Dish Hopper box which you plug into the wall outlet, screw on the SAT antenna cable and screw on the output cable to your HDMI box.
Unless something has changed with the newer units...........
Randy & Dee
2018 DX3 37TS
"Orange Crush"
