Old 05-08-2024, 06:30 PM   #1
Shore power issue
2021 Dynamax Force HD
We just took a trip from Texas to Daytona Beach, Florida running on generator power and had no problem. Got to our campsite turned off the generator and plugged in 50A shore power and it is not powering the RV. We tested the outlet with a voltmeter, and it is good. On the screen, next to AC source, it says delay.
Anyone know what this means? I donít see any breakers that are obviously tripped or blown fuses.
TexasChris is offline   Reply With Quote
Old 05-08-2024, 06:37 PM   #2
check the breaker at the pedestal?
use a multi meter start at the pedestal measure voltage on each leg
and then at the end of the power cord
and then at the ATS or Inverter/charger or distribution panel breakers etc
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 05-08-2024, 06:49 PM   #3
REBOOT.. the system
no shorepower / generator or battery for a x seconds?
Then connect shorepower first?
Tarpon Springs FL
2022 Salem 24RLXL
Old 05-08-2024, 06:51 PM   #4
How do I reboot the system?
2017 Forest River Georgetown 364TS
Old 05-08-2024, 08:24 PM   #5
CyberShanks's Avatar
I'd assume the same way I restart our Precision Plex XL. Turn off both chassis and house battery disconnects. Chassis disconnect is likely under drivers seat, house disconnect is likely in battery bay. Just turn them both off and give it 4 or 5 minutes, then turn em back on.
Jim
2021 Dynamax Dynaquest XL 3400KD
2022 Aluma 8220H Tilt flatbed to carry:
2012 Jeep JKU Rubicon or slightly modded 2001 Jeep TJ
CyberShanks is offline   Reply With Quote
Old 05-09-2024, 02:03 PM   #6
firedude2's Avatar
By any chance do you have a GoPower I/C? If it is, power up your inverter/charger first before hooking to a outside power source or generator. If you plug in or run your generator then power up the I/C it may not allow pass through or charging of batteries.
2023 Dynamax Europa
firedude2 is offline   Reply With Quote
power, shore power
