Originally Posted by shultz01
Nice. I hope to have a trailer like that some day. Would you have any pics of the inside you'd like to share?
Apologies it took me so long to get back to you I was busy digging my self out of ice and snow to leave the Colorado mountains.
Full size ramp that can support my 6.3k# truck there is also a side ramp at the front so I can unload the bike with out removing the truck
this is how I pack the front of the trailer for now the plan will be Etrack down the walls to make shelves and hopefully now that we are done in the tundra I can get rid of the huge roll of reflectix. The E track flush mounted in the ground was such a good choice makes stacking and loading easier than having bumps. I wish I did it for the wall but $$$ was already over budget for the trailer. So I will just DIY it to the wall.
the truck just fits perfect
-in the left tube is the bottom frame for my Skirt
-in the Thule I have my skirt and all of my snowboards the reflectix I cut for the slides ( I did full wrap around for the sides of the slides) and windows plus some other random winter storage things.
- in the right tube is my RV connect we boost antenna pole
I made these tubes and mounted them using unistrut the tubes an open from both sides
this is the power and solar control for my trailer
I can charge on - shore power plug 120v mounted outside on the tongue, Alternator from vehicle using 7pin tow connector, 200w solar on roof. I am running (2) 200ah LI ion batteries for the trailer. I use the power in there to run a battery tender for my motorbike and to charge my Goal Zero 3000k that I use as an inverter situation to run power tools or anything else I need in the trailer
The plan is to eventually put more solar and batteries on the trailer that I can then link up to my RV to make one huge solar system.
