01-10-2018, 03:23 PM
#81
Originally Posted by dlfishing
01-10-2018, 07:27 PM
#82
My controller for the cameras is in this area below the AV compartment in the over the cab bunk. The only thing going to the dash stereo headunit from the controller is an RCA video cable (black with yellow connectors).
Andy & Debbie Shultz
Harrisburg, PA
2021 Dynaquest XL 3801TS
01-10-2018, 08:35 PM
#83
Is your camera controller the large box on the outside of the cabinet or the small one that is just inside?
01-10-2018, 08:36 PM
#84
How many yellow connectors, 3 ?
01-10-2018, 08:38 PM
#85
I have been trying to get someone from Dynamax to tell me which are the left and right camera wires but so far no success
01-11-2018, 07:06 AM
#86
Side Cameras - I dont want them
It would be the smaller box down inside. It’s smaller than the HDMI splitter which is in there too.
The video cable has one yellow end connected to the controller and the second/other yellow end is connected to the headunit.
I used a tester and activated each turnsignal to determine which wires were the turnsignal wires.
Harrisburg, PA
01-11-2018, 07:17 AM
#87
Thanks, I hadn’t thought of that. Will try today.
01-11-2018, 09:33 AM
#88
What Shultz said. My box has 4 wires coming to it for signal and then 4 RCA connectors (3 in, 1 out). The pins were labeled on my box so it sounds like there may be some variation. I’ll try and grab a pic sometime but I probably won’t get to the unit for a few weeks
2016 Dynamax DX3 - Big Blue
01-11-2018, 04:38 PM
#89
Your two sounds the same on different models and years. Apparently mine is different or I’m fooling with the wrong wires.
01-28-2018, 09:30 AM
#90
Nice to be able to use my blinkers and GPS at the same time.
01-28-2018, 09:33 AM
#91
Awesome, nice work.
I am still wrestling with the idea of the separate monitor for the cameras, haven't talked myself into it yet. Maybe because I have a list of 100 others things I want to do to the new coach after delivery.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
01-28-2018, 09:42 AM
#92
I intend to do that as well but this is a step. I want to use a mirror mount monitor and install it in the spot intended for a CB radio. Considering the location of the camera controller, the wiring should be easy.
01-29-2018, 09:08 AM
#93
Nice solution! Glad you found it
