05-03-2022, 08:05 PM
Silencing the screen door on M2
Screen door looks to be squeaking pretty badly when we hit bumps on the super smooth roads we have these days.. It's one of those things that is hard to troubleshoot as I don't want someone sitting in the stairs while rolling down the highway to see where the noises are coming from. But, I think I found the culprit, the rubber seal on the screen door looks to slide around a bit in the frame and it makes the same squeak if I move it around. Would anyone have a recommendation of what to spray/wipe on the seal to make it quit? I know it's going to make noises going down the road, I'm cool with that, but this squeak is so annoying.
Thanks,
Jim
2021 Dynamax Dynaquest XL 3400KD
2022 Aluma 8220H Tilt flatbed to carry:
2012 Jeep JKU Rubicon or slightly modded 2001 Jeep TJ
05-03-2022, 08:15 PM
2022 Dynamax Europa 31SS
I have had the same issue that seems to come and go. I've had luck with Sprayway mold release spray because that is what I have on hand--it is a dry silicone that leaves no residue and is pretty slick. There are many others. I just spray all the gaskets around the door and that seems to help.
05-03-2022, 08:18 PM
We may have a different screen door on our 2018, but I put a piece of adhesive neoprene on the back of the screen door latch, keeps it from rubbing on the door and squeaking. Also on the older unit doors “Challenger Doors” the lock is held on with 3 or 4 allen screws on the side of the door, they work loose and also squeak. I put a little bit of Blue Loctite on them, put them back in and got rid of all the squeaks.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
05-03-2022, 08:19 PM
Thanks, I was actually thinking some sort of dry silicone spray, figured I'd ask first though. I know, such real-world problems I bring...
Jim
05-03-2022, 08:23 PM
I believe Dynamax did change doors in 2020 or 2021, the newer ones have a metric crapton of bolts on the hinge side, all of those are tight, I'll check again though. The door is very heavy duty, just the screen door part slides around a bit.
Thanks,
Jim
05-04-2022, 04:59 AM
Steve & Linda M.
You might be able to adjust the screen door latch enough to put a bit more pressure on the seal. I've done this in the past to eliminate the majority of squeaks. The dry lube may help, as well.
Started in the "Pumpkin" '79 Burnt Orange Dodge "Street Van" ... NW cruise, Canadian Rockies, Round trip to Alaska. Then' 94 Tioga Montara, '06 Jayco Jay Flight 5th Wheel. Workmanship decline started : '15 Thor Siesta & '17 Tiffin Breeze.
Another RV learning experience with our 2022 34KD Force.
2019 Jeep KL (Cherokee) TOAD
05-04-2022, 08:56 AM
Also check the plastic slider in the screen door. If I leave mine in the open position it squeaks while driving. Now I close the plastic slider before driving.
Sent from my SM-G930T using Forest River Forums mobile app
05-04-2022, 07:55 PM
You might try lubricating the main door latch post. It slides up and down. Had awful squeeks till I lubricated this part inside and out. Squeeks went away.
05-04-2022, 07:58 PM
quick fix
Put one wrap of black electrical on the door post stud. The small post midway up the door on the body. Noise will go way, but the tape will eventually wear thru. Then replace the tape, simple fix, been doing it for years.
