Old 10-08-2019, 05:24 PM   #1
Whalenss's Avatar
Sirius radio antenna error
Anyone know what this error message is and how to fix?
Pat
2017 Isata 5
Whalenss is offline   Reply With Quote
Old 10-08-2019, 05:38 PM   #2
milkman55's Avatar
Assume you previously had uninterrupted Sirius XM radio service and didn’t just activate. What I found was the Sirius receiver just hangs free behind the radio and the antenna is plugged in. There were numerous reports of the antenna coming loose from the receiver and the solution was to zip tie the receiver so it didn’t move around and then re-seat the antenna and tie it down as well to keep it from moving around.
2021 Isata 5 30FW
2014 Honda CR-V
milkman55 is offline   Reply With Quote
Old 10-08-2019, 06:00 PM   #3
Whalenss's Avatar
Yes, had uninterrupted service. Started on last trip.
Pat
2017 Isata 5
Old 10-08-2019, 08:38 PM   #4
halla's Avatar
I would check the antenna and contact the dealer. Lol. Sorry had to throw that out.
I would check the Sirius tuner to see if the antenna worked loose or the back of the radio. May try pulling the fuse for the radio and see if it resets.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
halla is offline   Reply With Quote
Old 10-08-2019, 08:56 PM   #5
MouseHouse's Avatar
I sure wouldn't want to meet you in a dark alley.
2021 Dynamax DX3 37RB
(Formerly 2018 Dynamax Isata 5 36DS)
MouseHouse is offline   Reply With Quote
Old 10-08-2019, 11:34 PM   #6
KRedburn's Avatar
most likely the antenna connection has come loose. Happened a lot on the farm tractor this past harvest.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 10-09-2019, 11:13 AM   #7
Whalenss's Avatar
Aaron, you are such a comedian, but don't quit your day job just yet. [emoji1]
Dealer says there were several error codes for the radio so cleared the codes and seems to be good.
Will see if it comes back on the next trip.
Thanks to all who responded with suggestions.
Pat
2017 Isata 5
antenna, radio
