The bedroom push-out on our 2019 Dynaquest XL 3801TS exploded while bringing the unit in. The MH was level and the equalizers were extended. There was an extremely loud bang and the slide started moving in an unequal manner. I was able to push the bedroom slide in manually and get it home.
The forward lower pulley assembly was torn off the attachment point and one of the cables snapped at the bolt threads were it attached to chain bridle. It appeared to be a result of the forward chain bridles locking together while one is moving forward and the other is moving aft. The distance between the bridles is minimal even when they are both vertical. I could have used a heads up on this system. I would have inspected the cable tension and bridle orientation every few months.
One cable had to be replaced with a repair kit and the entire system re-rigged. Both forward and aft cable/chain bridles now have a metal strip ensuring the bridles do not touch and lock together. This is a poor design and requires occasional inspection to ensure proper cable tension. The separation strip should prevent a major failure and damage.
Attached are the photos of before and after.
