Originally Posted by MasterBlaster
Not sure on your unit, but our cable slides will not work with the ignition turned on. Try turning off the key and see if they work.
^^Yes, try this.^^
The cable slide system is a different MFG from the front slide and their "installation requirements" are different from the other MFG. I would have preferred that we contact the cable slide people and get an exception so they can be the same, but I think we just installed them per the recommended style (one wants the engine and one does not).
Going forward, we have talked about changing over the rear slide to the slim-rack, which would make it the same MFG as the front slide and they should operate the same.
