Originally Posted by Just_In_Time
Warranty company won’t cover since it’s not a mechanical failure. So now I’m planning my fix. If I go from the bottom up, what would I be anchoring the aluminum frame to? Really same question for the aluminum angle approach. I would imagine I would be drilling through the wood subfloor into the aluminum frame but for the wall, is there aluminum frame there too or is that straight into thin wood wall/fiberglass exterior? I’ve been searching for that thread you mentioned with no luck. I found a similar thread with the issue on a Rockwood, but they used aluminum angle on the exterior.
Found it....it was on Facebook. That is why search was not working.
This is the relevant part.
