Slide LEDs flashing alternately no such code
Went to extend the slide today, no movement, no noise, no hum, just the fault red LED and the green movement LED flashing alternately for 4 to 5 minutes then go off. There is no code like that anywhere in the manual. Checked voltage- OK reset power- no help. Checked the module under the slide in a basement compartment- seems ok, no lights on the module. Anyone have any idea what the problem is? Have not had any problem before with the slide
2018 isata 3 FW
2014 Jeep JK Rubicon
