Old 10-21-2021, 05:42 PM   #1
caseymyers's Avatar
Slide outs not responding
Went to put out a slide and no op. The red light flashing for parking brake but the brake is on. Engine and generator are running. Ideas?
2019 I5 DS.
caseymyers is offline   Reply With Quote
Old 10-22-2021, 06:52 AM   #2
SeaDog's Avatar
it may be that your coach batteries are not charged try starting over after charging the coach batteries to 100% JMHO
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-22-2021, 07:59 AM   #3
Commercial Member
The early ones, I don't think the engine should be running. Gen yes, engine? Unless you are sure that is how you have done it in the past.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 10-22-2021, 08:49 AM   #4
caseymyers's Avatar
I think Iíve opened slides with the engine running but will try it with just the gen. Manual doesnít say anything about the lights flashing for parking brake other than to put the brake on. I was thinking maybe what ever tells the slide controller that the brake is on has failed. I just had a transmission service done at my Ram dealer, could the tech have disconnected something that talks to the controller?
Old Navy Chief
2019 Isata 5 36' DS 4x4
2015 Jeep Rubicon Toad
Days camped 2021 = 25
Old 10-22-2021, 09:32 AM   #5
My DX3 is a 2018 and you have to have the ignition on to move the slides (the main slide works either way)
Point is, ours quit working when it was in the out position. I went to the slide control module, unplug it and put it back in and they started working.
Might want to give that a try
Orangecrush is offline   Reply With Quote
Old 10-22-2021, 10:29 AM   #6
Just in case you haven't tried the obvious, release the brake and reset by really mashing down on the pedal. Maybe it's not making contact.
Tom and Becki
2018 Isata 5 30FW 4X4
bratbros is offline   Reply With Quote
Old 10-22-2021, 07:47 PM   #7
I had a similar issue with my DX3. The parking brake was on but rear slide and the jacks wouldnít work. The panel for the jacks had the flashing red light, parking brake not engaged.
On the DX3 there is a sensor on the air brake line in the engine compartment with 2 wires that tell the the controller if the parking brake is on. I cleaned the connectors to those 2 wires and it solved the issue. I bet there is a similar sensor somewhere in the engine compartment.
There is a thread on this forum from my issue with pictures.
scuderiascappaticci is offline   Reply With Quote
Old 10-22-2021, 07:56 PM   #8
caseymyers's Avatar
Thanks, thatís where my mind is going. Just had the tranny serviced, maybe he knocked something loose.
Old Navy Chief
Old 10-23-2021, 07:31 PM   #9
You have pics of that connector?
Old 10-23-2021, 07:34 PM   #10
I do not and my DX3 is in storage so I canít take a picture.
Old 10-27-2021, 07:13 AM   #11
Dynamax Service Rep
Hey Casey,its Greg,pull the kickpanel next to the park break,there is either a harness there that we used to use to pick up our brake signal,or there are three connectors that do the same in the newer units.
GTinsman is offline   Reply With Quote
Old 10-27-2021, 08:46 AM   #12
caseymyers's Avatar
Thanks, good to hear from you, hope all is well. I told Brian Iíd sign up for work camper, but only if I could work for you on your repair crew. Iíll t pull that panel and look for lose connections. Danielle also sent me the video on resetting stops so Iíll try that too.
Old Navy Chief
Old 11-02-2021, 09:36 AM   #13
caseymyers's Avatar
Slides are working now. Ran the black wire to ground to trick the controllers into believing that the emergency brake is always on. Not a perfect solution but hey, I can operate my slides. Thanks to all.
Old Navy Chief
Old 11-02-2021, 01:31 PM   #14
caseymyers's Avatar
What kind of Dynamax do you have?
Old Navy Chief
Old 11-02-2021, 02:07 PM   #15
bikendan's Avatar
Who are you asking? It's always best to quote the member's post that you're responding to.
slide, slide out
