Update of diagnosis. The motors are working correctly. The slide is trying to open but the frame of the slide is binding. The frame is tight on the plywood cover for water tank. This is the area of the bed corner by the back wardrobe. When I look under the mattress I can see a 1/2" gap, on the right side, between the plywood water tank cover and the wood box piece the mattress lays on. (The right side being the side toward the front of vehicle). The left side, the mattress wood box is directly on the plywood water tank cover. So, the problem seems to be, something broke? Allowing frame/box to drop? Something possibly jammed in between water tank plywood cover and bottom of slide? Anyone have or had a similar problem? Thanks!
Space Cowboy
2018 Isata 5 30FW
