Just a FYI,
When my rear slide motor quit I also could not release the brake. I removed the motor from the slide mechanism and had a helper push on the rear and bumped the front motor from the controller. We got it in and happily moved down the road. After that I put in "kill solenoid and a control switch" due to others having problems with self deployments. Replace the motor and reset stops. Have had zero problems since. On the motor I took out, I found that the brake mechanism was rusted up due to a torn rubber seal over the brake arms. I removed the brake and keep the motor as a "spare".
FYI new motor for a 2018 slide from Lippert is around $750. ouch!
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
