Have a 2021 Isata 3 24fw and on the go pro controller the meter flashes 14.4 at least 3 times then very briefly it will show 12.7 which is battery voltage,is this normal?
I am guessing that it is set for AGM, 14.4 is the charge voltage, 12.7 would be a battery voltage so it could be cycling between both items or if you are plugged in, or engine running it could be picking up the charge voltage on the batteries.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
